Hi, building my first computer and being very nervous i would like to know a few thing about these parts i’ve put together.
1. Are they all compatible? I’m a little nervous that i might not have a big enough power supply, or to few connectors on my motherboard or you know anything that needs to be changed.
2. Is this enough cooling, I’m not going to do any overclocking.
3. Of course anything that is wrong or might become a problem...
4. And general thoughts on this build. :)
ASUS Z170 PRO GAMING, Socket-1151 ATX, Z170, DDR4, 3xPCIe-x16, DVI-D, HDMI, M.2, SupremeFX, GameFirst III
Cooler Master V8 GTS CPU Kylare 755/115x/2011/2011-3/1366, AM2(+)/AM3(+)/FM1/FM2, 600~1600 RPM, 28~82 CFM
Corsair CX 750M, 750W PSU ATX 12V V2.3, 80 Plus Bronze, Modular. 4x 6+2pin PCIe, 8x SATA, 6x Molex
Corsair Vengeance Pro DDR3 2400MHz 16GB 2x8GB CL11 XMP 1,65V
Gainward GeForce GTX 970 4GB PCI-Express 3.0, DL-DVI-I, HDMI 2.0, 2x mini-DisplayPort, UEFI
Intel Core i7-6700 Skylake Socket-LGA1151, Quad Core, 3.4GHz, 8MB, 65W, 14nm
Samsung 850 EVO 250GB SSD SATA6.0Gbps, 3d V-nand 32 layer,MGX ctrl, 540/520 MB/s R/W
Seagate Barracuda® 2TB SATA 6Gb/s (SATA 3.0), 64MB Cache, 7200RPM, 3.5”
Cooler Master SickleFlow 120mm Blue LED 120 x 120 x 25mm, 2000 RPM, 69.69 CFM, 19 dBA, 3 to 4-pin Adapter    (I’ve got 4 of these.)
NZXT LEXA S Midi Tower Black Fans: 1x 120mm Front, 1x 120mm Side, 1x 140mm Topp, 1x 120mm Bak, mATX, ATX
Full list of the things I'm buying, warning Swedish site: https://www.komplett.se/k/shoplist.aspx?mode=receive&si=1629049&su=FC9A4006-A470-4DD1-B55E-8E6961817285
Have a nice day!
https://linustechtips.com/topic/497501-help-with-a-new-build/
Have a nice day!
Get an H170 PC Mate Motherboard, AMD R9 390, NZXT S340 Case, Cooler Master Hyper 212 EVO CPU Cooler
https://linustechtips.com/topic/497501-help-with-a-new-build/#findComment-6649798
The RAM you picked is DDR3 this board only supports DDR3
Is this a gaming build? If so don't get the i7 and get a i5 6600K and a better GPU, maybe a R9 390x or 980ti.
Don't get a CX750 get a GS/G2/S12 power supply.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/497501-help-with-a-new-build/#findComment-6649813
-snip-
While being semi nervous is understandable, be calm. You have the LTT community to help you out here. You can feel safe knowing we will help! So DEEP BREATH, lets do this.
With the Z170 boards you have to use DDR4 or DDR3L memory. So your memory is not compatible from what i see there.
Get a different Power Supply. The CX series is for casual use and not for Gaming. Check my GUIDES section of my sig for a PSU buying guide.
Everything else looks good. Cooling is important and you got that covered.
Intel Core i7-6700k | 2 X Gigabyte 4GB GTX 970 Overclocked Edition | 16GB (4X4GB) DDR4 2133MHz Corsair Dominator Platinum | MasterCase Pro 5
ASUS Z170 Deluxe Motherboard | 256GB Samsung 840 Pro + Seagate 2TB Storage | Corsair Hydro H80i GT | Windows 10 Pro 64bit | Corsair HX850i
https://linustechtips.com/topic/497501-help-with-a-new-build/#findComment-6649829
Have a nice day!
if you are not going to overclock get a H170 Motherboard from Asus, CPU cooler is fine, Also choose graphics card from Asus or MSI, get Gtx 970 or amd R9 390,
another thing is that some 6th gen motherboards support ddr3 ram but intel warns that it will decrease the lifetime of product, so its better you use DDR4 ram,
for power supple, you can bring it down to 600 or 650w no need for 750W
other than that its pretty good
https://linustechtips.com/topic/497501-help-with-a-new-build/#findComment-6650647
Have a nice day!
https://linustechtips.com/topic/497501-help-with-a-new-build/#findComment-6650672
