Microsoft Edge Review Question
Hey Guys,
I am thinking about switching over my browser to Microsoft Edge for 13 days. I was think of putting an LTT Blog Together and recording my 13 day experience. Would this be something that you would follow/ enjoy to see. I will give more details if  I Move forward. Please Provide COmmentary on whether or not you would want to see this.
Thx
Chase
Chase B
Sound Tech and GPU Expert
Are You New? Please Click on these links to help you out. Code Of Conduct | LTT Beginners Guide
https://linustechtips.com/topic/497201-microsoft-edge-review-question/
We already know its bad, dont waste your time hehe
My Rigs:
Gaming/CAD/Rendering Rig
Case:
 Corsair Air 240 , CPU: i7-4790K, Mobo: ASUS Gryphon Z97 mATX,  GPU: Gigabyte G1 Gaming GTX 970, RAM: G.Skill Sniper 16GB, SSD: SAMSUNG 1TB 840 EVO, Cooling: Corsair H80i PCPP: https://au.pcpartpicker.com/b/f2TH99SFF HTPC
Case:
Silverstone ML06B, CPU: Pentium G3258, Mobo: Gigabyte GA-H97N-WiFi, RAM: G.Skill 4GB, SSD: Kingston SSDNow 120GB PCPP: https://au.pcpartpicker.com/b/JmZ8TW
Give it a chance, It is new and that is why  I want to do this
Chase B
We did give it a chance, its bad xD It's not as bad as Internet Explorer by ANY means under the Sun... but it's still pretty bad. Stick with Chrome ;)
"What're you supposed to be? A clown or something?"
"...Sometimes."
its decent, but this far after release its still pretty awful, Ive been using it as my daily driver since release day. Stupid issues like copy/paste not working on sites like these forums and google docs are super annoying. Websites like Vessel, I cant skip around videos using the progress bar. Sometimes on forums (LTT and others) I simply cant type in the reply fields. All these issues Ive reported to MS several times for months.
I feel like im in too deep to switch back T.T
Gaming - Ryzen 9800X3D | 64GB 6400mhz cl30 9070 XT
Homelab - many servers...constantly changing.
3970X/256GB - 5950X/128GB ECC - 5600G/96GB - 3400GE/16GB - 3400GE/16GB
I don't think you would end up with enough content every day. After just a day or two you would probably know like 90% of the conclusion. I mean, it's a web browser. Otherwise than features and compatibility there isn't really much else to say. If either of those things end up being an issue for you then you will notice it almost right away.
Try it if you want, but it might be more suitable to try it for 13 days, take notes and then write a single, detailed post about it.
How can you be "in too deep" to switch? It's just a browser. With Firefox I can understand since you can spend lots of time tweaking it to be just the way you want it, but with Edge tweaking basically stops at changing your home page.
Is it something that interests you??
Chase B
I'd read it if I found it. Personally I can't stand using Edge but it's interesting to hear what other people think. Edge is probably good for most people, but then again a huge amount of people are perfectly okay with IE 8 as well so...
Even I can't stand Edge until those essential features start rolling in. It's TREESH.
Having problems with your fresh Windows 10 install? PM Me!
Windows 10- Want To Disable Telemetry, Disable Cortana, Disable Windows Updates? Look at my guide HERE
LTT Beginners Guide  | Community Standards | TN&R Posting Guidelines
