http://uk.pcpartpicker.com/p/GdvQrH
Is it good enough to game on? Can it be improved while staying in the range of £800-900? Thanks for any help
PSU ALERT: Heads down the CX comments are coming.
That PSU is for basic PC use only not for gaming. Get a better PSU if you wish to game.
Intel Core i7-6700k | 2 X Gigabyte 4GB GTX 970 Overclocked Edition | 16GB (4X4GB) DDR4 2133MHz Corsair Dominator Platinum | MasterCase Pro 5
ASUS Z170 Deluxe Motherboard | 256GB Samsung 840 Pro + Seagate 2TB Storage | Corsair Hydro H80i GT | Windows 10 Pro 64bit | Corsair HX850i
https://linustechtips.com/topic/497042-pc-build-opinions/#findComment-6645239
You beat me to it. I'll say it anyways...
*inb4 CX is terrible comments*
i7 4790k | GTX 970 | 16GB
That's all you need to know. It's a beast.
https://linustechtips.com/topic/497042-pc-build-opinions/#findComment-6645256
get a better graphics card like the r9 380 or 390 and don't bother getting an aio liquid cooler unless you plan on overclocking your cpu a lot
https://linustechtips.com/topic/497042-pc-build-opinions/#findComment-6645258
Get a 380x or 380 4GB over the 960, also a different PSU from seasonic/evga
edit: you have an overclockable CPU but not a motherboard that supports it. You need a Z97 mobo.
FX-6300 cooled by Nepton 240M | EVGA GTX 970 SuperClocked | 8GB G.Skill ValueRAM | Cooler Master 690 III | Sharkoon WMP 500 Bronze
Power supplies:
http://linustechtips.com/main/topic/406160-psu-ranking-and-tiers/ My F@h stats: http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=zyntaxable Intel vs. FX for gaming: http://linustechtips.com/main/topic/401217-more-updated-fx-vs-intel-for-gaming/
https://linustechtips.com/topic/497042-pc-build-opinions/#findComment-6645261
he shouldnt get a K processor either if he doesnt wish to OC, which will save some cost as well. Maybe put it into a PSU?
https://linustechtips.com/topic/497042-pc-build-opinions/#findComment-6645270
You can save yourself some money by going for a 500-550W PSU, and getting a slightly better GPU.
CPU: Ryzen 5 3600X            | Cooler: Deepcool AK400  | Motherboard: B550 Elite AX V2  | Storage: Samsung 980 Pro 1TB  |
RAM: Corsair Vengeance 16GB   | GPU: MSI RTX 3060 Ti    | Case: NZXT H440 (Red/Black)    | PSU: EVGA 650W G2             |
https://linustechtips.com/topic/497042-pc-build-opinions/#findComment-6645273
Thanks, any recommendations for a good psu?
Any from seasonic or evga g2
Power supplies:
https://linustechtips.com/topic/497042-pc-build-opinions/#findComment-6645285
*rages about CX*
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/497042-pc-build-opinions/#findComment-6645286
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  (£174.50 @ Amazon UK)
CPU Cooler: Noctua NH-U12S 55.0 CFM CPU Cooler  (£46.18 @ CCL Computers)
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard  (£64.74 @ Aria PC)
Memory: Kingston HyperX Fury White 16GB (2 x 8GB) DDR3-1866 Memory  (£62.92 @ More Computers)
Storage: Sandisk SSD PLUS 240GB 2.5" Solid State Drive  (£57.88 @ Amazon UK)
Video Card: XFX Radeon R9 380 4GB Double Dissipation Video Card  (£159.59 @ Overclockers.co.uk)
Case: Corsair SPEC-03 Red ATX Mid Tower Case  (£45.98 @ Novatech)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply  (£51.36 @ CCL Computers)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer  (£9.00 @ CCL Computers)
Wireless Network Adapter: TP-Link TL-WDN4800 802.11a/b/g/n PCI-Express x1 Wi-Fi Adapter  (£24.99 @ Amazon UK)
Monitor: Asus VC239H 60Hz 23.0" Monitor  (£114.88 @ More Computers)
Total: £865.48
Generated by PCPartPicker 2015-12-01 21:23 GMT+0000
https://linustechtips.com/topic/497042-pc-build-opinions/#findComment-6645311
http://uk.pcpartpicker.com/p/8LLXD3
Okay, here's a revised build. Any further tweaks?
Not worth liquid cooling a locked CPU, get a cheap air cooler like the CRYORIG H7, be quiet! Pure Rock, CM Hyper 212 EVO or Noctua NH-U12S. Will likely perform better than the H55, too.
EDIT: @The Official Czex's build was great, you should look at that @Manonthemoon.
Other systems I've built:
https://linustechtips.com/topic/497042-pc-build-opinions/#findComment-6645338
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (£34.98 @ Amazon UK)
Case Fan: Corsair Air Series SP120 Quiet Edition (2-Pack) 37.9 CFM 120mm  Fans  (£18.48 @ Amazon UK)
Total: £865.48
could I drop the cpu and just go for a non over clockable one?
https://linustechtips.com/topic/497042-pc-build-opinions/#findComment-6645355
Why would you want to?
https://linustechtips.com/topic/497042-pc-build-opinions/#findComment-6645369
Why? He got you a Z97 board and overclockable CPU within budget, why would you not? If needs be you could just not overclock it. At least you'd have the option in the future.
https://linustechtips.com/topic/497042-pc-build-opinions/#findComment-6645387
