980ti high temps?
First of all do not worry at all. These temps are quite normal for Maxwell cards with a GM200 chip under air. My Titan Xs were way worse with the standard heatsink. The STRIX is a fine card that has a custom PCB and a very good VRM block.
Then let us talk about then myth about Lightning and Kingpin for a second. The MSI Lightning is a card with a big cooler that is not exactly known to be super quiet unlike the STRIX because the focus of this card is not performance and be as quiet and enjoyable as possible in games, no it is maximum performance. Does it mean you can OC higher? No it doesn´t and the reason for that is when it comes to Maxwell cards there´s more to eyxtrem OCing than just a big cooler or a cherry picked chip.
Alright then there´s the other story about the Kingpin from EVGA... the Kingpin is nothing but the final version of the Classified. A bit more refined but that´s about it. Is that all? No there is more to it. First of all extrem OCing starts with performance watercooling and goes up to LN2.... not air cooling. The Kingpin is such a card made for extrem OCing best case with LN2. Now is this the best OC card out of the box? Nope sorry to destroy that myth too but the best OCer out of the box is the EVGA Classified, and the reason for that is, that it is pretty much the only card that is not part of nVidia´s Greenlighnt program. In order to use the Kingpins full OC potential you need a hardware device to unlock the voltage manually.
