Posted December 1, 2015 So I really want to change the thermal paste of my GPU, but I can't do that because i can't buy alcohol anywhere. Could I apply the paste on top of the other paste? I'm pretty sure there won't be a lot of it since its been two years since I've owned this R9 270X but it gets up to 90C in games, which is definately not okay. Any help is appreciated thanks Link to comment https://linustechtips.com/topic/496919-thermal-paste-question/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 1, 2015 you can just use a small damp cloth with water to clean the old paste off it doesnt need to be alcohol NEW PC build: Blank Heaven minimalist white and black PC Old S340 build log "White Heaven" The "LIGHTCANON" flashlight build log Project AntiRoll (prototype) Custom speaker project Spoiler Ryzen 3950X | AMD Vega Frontier Edition | ASUS X570 Pro WS | Corsair Vengeance LPX 64GB | NZXT H500 | Seasonic Prime Fanless TX-700 | Custom loop | Coolermaster SK630 White | Logitech MX Master 2S | Samsung 980 Pro 1TB + 970 Pro 512GB | Samsung 58" 4k TV | Scarlett 2i4 | 2x AT2020 Link to comment https://linustechtips.com/topic/496919-thermal-paste-question/#findComment-6644079 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 1, 2015 snip Window cleaning solution, applied to a clean cloth and then use the cloth to wipe it should also work. You can buy alcohol from any pharmacy, just tell them you are looking to buy a small bottle of rubbing alcohol. If you use water to wet the cleaning cloth or towel, make sure the board is properly dry after cleaning. You don't want any moisture or water residue left on the board. Guide: DSLR or Video camera?, Guide: Film/Photo makers' useful resources, Guide: Lenses, a quick primer Nikon D4, Nikon D800E, Fuji X-E2, Canon G16, Gopro Hero 3+, iPhone 5s. Hasselblad 500C/M, Sony PXW-FS7 ICT Consultant, Photographer, Video producer, Scuba diver and underwater explorer, Nature & humanitarian documentary producer Link to comment https://linustechtips.com/topic/496919-thermal-paste-question/#findComment-6644087 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 1, 2015 when i'm out of alcohol i use perfume, realy it's not a bad idea Link to comment https://linustechtips.com/topic/496919-thermal-paste-question/#findComment-6644092 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 1, 2015 when i'm out of alcohol i use perfume, realy it's not a bad idea Your computer must smell good then Wow this was old as heck, Need to update this signature! Link to comment https://linustechtips.com/topic/496919-thermal-paste-question/#findComment-6644102 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 1, 2015 Your computer must smell good then i do remeber my 980ti smell when i just bought it. it smell better then my girlfriend Link to comment https://linustechtips.com/topic/496919-thermal-paste-question/#findComment-6644128 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 1, 2015 Alcohol prep pads from a First Aid kit are also great for removing thermal paste. You can usually buy these as Alcohol wipes/Prep pads/cleaning wipes etc. from Pharmacy or other General store. Otherwise, just use a clean cloth or paper towel and wipe as much off as possible. Honestly, if its still wet thermal paste, a little left behind wont matter. If its hard and cracked, it will probably easily come off in chunks anyway. Alcohol is used because it dissolves the thermal compound, and evaporates quickly eliminating a chance of short circuit. The lower the alcohol content, the longer it will take to evaporate/dry so make sure that all the liquid is removed/evaporated/completely dry before powering anything on... [spoiler=REDWING] REDWING | Custom Hard Line Water Cooling Loop | Intel i7-4790K @ 4.7Ghz | Asus Maximus VII Ranger | Corsair Dominator Platinum DDR3-2400 2x8GB | 2 x Gigabyte GTX970 G1 Gaming (SLI) | Corsair AX860i | Samsung 850 Pro 512GB | Corsair Obsidian 750D | Corsair K95 RGB & M65 RGB | Samsung SyncMaster S27B370 Project Redwing Build Log [spoiler=ZedNAS] 'ZedNAS' Home NAS Build | Intel Xeon E3 1231 v3 | ASRock Rack E3C224D4I | Kingston KVR16E11/8I 2x8GB | Corsair HX750 | 6 x HGST Deskstar NAS 4TB 7200RPM HDD | Fractal Design Node 304 mITX Black | FreeNAS w/ PleX | ZFS Raid-Z2 (16TB Effective) | Link to comment https://linustechtips.com/topic/496919-thermal-paste-question/#findComment-6644157 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 1, 2015 The little lint free lens cleaning disposable pads work really well too.Like these: http://www.amazon.com/Zeiss-Alcohol-Pre-Moistened-Cleaning-Wipes/dp/B0155JRBMK CPU: Ryzen 1600X @ 4.15ghz MB: ASUS Crosshair VI Mem: 32GB GSkill TridenZ 3200GPU: 1080 FTW PSU: EVGA SuperNova 1000P2 / EVGA SuperNova 750P2 SSD: 512GB Samsung 950 PROHD: 2 x 1TB WD Black in RAID 0 Cooling: Custom cooling loop on CPU and GPU OS: Windows 10 Link to comment https://linustechtips.com/topic/496919-thermal-paste-question/#findComment-6644566 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 2, 2015 i do remeber my 980ti smell when i just bought it. it smell better then my girlfriend Haha yea I like the smell of new PC parts for some reason Wow this was old as heck, Need to update this signature! Link to comment https://linustechtips.com/topic/496919-thermal-paste-question/#findComment-6647343 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
