I have $800 dollars for a build and i dont know whats better the R9 380 or the R9 390
Is the only Difference the ram?
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard  ($89.99 @ Newegg)
Video Card: PowerColor Radeon R9 390 8GB PCS+ Video Card  ($279.99 @ Newegg)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($56.10 @ SuperBiiz)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply  ($47.60 @ SuperBiiz)
Total: $799.28
Generated by PCPartPicker 2015-12-01 04:20 EST-05000500
https://linustechtips.com/topic/496700-plz-help/#findComment-6641720
Total: $799.28
I would possibly suggest the 380x and instead upgrade that PSU with the money saved. But that's just my few cents.
https://linustechtips.com/topic/496700-plz-help/#findComment-6641730
the 390 is a high tier card right after the Fury series
so pretty much this
380 < 390 < Fury < Fury Nano < Fury X
RAM only say part of the story
the higher series number mean the GPU is more powerful than the lower series
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/496700-plz-help/#findComment-6641942
