PSU Cabling problem...
Go to solution Solved by MourningSouls,
I would grab two cheap 6+2 extensions, pull the wires and replace the GPU side connectors. Then hide the +2's in the back.
Hey guys!
I recently bought a Cooler Master Pro M2 1000w power supply, but I have ran into a little problem...
http://www.coolermaster.com/powersupply/silent-pro-m2/silent-pro-m2-1000w/
The power supply has modular slots for 3 x 6pin cables.
The supplied cables are all 6pin male (to psu) to 8pin + 6pin males. (to gpu)
I have 2 x 680 GPUs that both use 2 x 6pin connectors.
I want a solution that will be the most pleasing to the eye, what do you guys think I should do?
I though about getting custom extensions, that start with a 6 pin male and ends with one, but the one on the end pig tails into another 6 pin male.
The other option is to cut the one 8pin connector into a 6pin like the picture I have below:
https://linustechtips.com/topic/496687-psu-cabling-problem/
I have custom sleeved cables in my PC and it was absolutely worth it. It's so pleasing to the eye.
The Beast: CPU: i7 4790K GPU: EVGA 1080 SC Cooling: Dual NZXT Kraken x61 RAM: HyperX Fury 1866MHz Storage: SSD: 500GB Samsung EVO 840 + HDD: 1TB WD MOBO: Asus Z97 - a PSU: RM850x Case: H440 green-black Setup: Link PCPP: Link Evolution: Link
Gear: PS4 with custom skin // Astro A50 Xbox edition to fit colour scheme // Oppo PM-3 Planar Magnetic Closed Back Headphones // OnePlus One 64GB sandstone
Other stuffs: Acer aspire 128GB SSD 10GB RAM // MacBook Pro 13" 500GB SSD 16GB RAM // A 2009 iMac 21"
https://linustechtips.com/topic/496687-psu-cabling-problem/#findComment-6641566
The guys that can do it here (In south africa), said it is going to be difficult to sleeve the cables and pig tail them. Apparently 2 x cables and sleeving wont fit in a connector.
https://linustechtips.com/topic/496687-psu-cabling-problem/#findComment-6641581
INTEL CORE i5-7600K | ASUS ROG STRIX B250i GAMING | CRUCIAL BALLISTIX SPORT LT 16GB | EVGA GTX 970 SC | EVGA B3 550W
SAMSUNG 850 EVO 250GB | CRYORIG M9i | BE QUIET! PURE WINGS 2| FRACTAL DESIGN DEFINE NANO S
https://linustechtips.com/topic/496687-psu-cabling-problem/#findComment-6641589
You beast! I will do this! Can I pull those molex pins without the proper tools?
https://linustechtips.com/topic/496687-psu-cabling-problem/#findComment-6641602
Shouldn't be a problem, I think I used some tweezers and a knife. Just squeeze the little clip things and extract, then expand them before inserting into the new connector.
https://linustechtips.com/topic/496687-psu-cabling-problem/#findComment-6641619
Hey guys!
I managed to get other connectors on my modular cables, I think it came out pretty sweet!
I now have 2 cables that are 6+2 pigtailed to 6+2 and 1 cable that still has the 8pin and a pigtail 6 pin! Im still wondering why Cooler Master didn't just make them like this from the get go...
https://linustechtips.com/topic/496687-psu-cabling-problem/#findComment-6665244
