Not bad. Maybe throw a cooler in there to reduce temps and noise? Would give you room to overclock depending on the cooler as well.
And if it's in your budget, an SSD is totally worth it.
i7 4790k | GTX 970 | 16GB
That's all you need to know. It's a beast.
https://linustechtips.com/topic/496190-my-first-pc-build/#findComment-6636444
How is this for a first pc build?
http://uk.pcpartpicker.com/p/brnFvK
One small tweak
http://uk.pcpartpicker.com/p/Yq8sD3
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
https://linustechtips.com/topic/496190-my-first-pc-build/#findComment-6636445
Everything is good but you can get a better monitor for just a bit more money... Also make sure to get a SSD too...
I dont have the extra money :/
But I prefer 1080P, because I will get better FPS with the R9 390x
Thanks for reading this! Shame that there's nothing here worthwhile for you to read... but you are still reading. Why?
https://linustechtips.com/topic/496190-my-first-pc-build/#findComment-6636475
Looks good to me, although you might want an SSD. I usually recommend using Intel Smart Response (Using an SSD as a cache, more about that here: https://www.youtube.com/watch?v=kgYPk2j5PNM
If you do this, get an M.2 SSD (port on the motherboard) that's between 32 and 64GB.
Another thing, remember that a copy of Windows is not included with any of the parts. You'll need to buy one online (like a disc) or a key from somewhere online (reddit, etc)
Welcome to LTT! Feel free to PM me if you just wanna chat, I love conversation!
If you ever have any audio questions, wether it's software, hardware, or production and theory, feel free to ask me. Odds are I can help you, or get you help.
https://linustechtips.com/topic/496190-my-first-pc-build/#findComment-6636476
What version of windows should I get?
https://linustechtips.com/topic/496190-my-first-pc-build/#findComment-6636504
10 master race bruh 64 bit.
https://linustechtips.com/topic/496190-my-first-pc-build/#findComment-6636506
Depends on your choice. 8 (64bit) is super cheap right now. I like 8 better than 10
https://linustechtips.com/topic/496190-my-first-pc-build/#findComment-6636527
As everyone's been saying, an SSD would be optimal. I'd keep the HDD for mass storage (although I'd get a Seagate, they're equally reliable and a bit cheaper), and get a small, maybe 120-250 GB SSD configured as the boot drive for the operating system and some frequently accessed applications. This way you keep good boot speeds and startup times, but still have the added benefit of inexpensive storage. Crucial's MX100 SSDs are legendarily good "bang for the buck."
Also, (again nothing really that new here) if you save up a little more money you may want to consider getting a decent CPU cooler so you can overclock it some. After all, you are getting a "K" series processor, made specifically for overclocking.
https://linustechtips.com/topic/496190-my-first-pc-build/#findComment-6638520
