Java Help
Hey Guys
Just need pointing in the right direction as to how to go about this task:
Design and make a Java application to show your programming skills such as a Lottery style game; inputting numbers to see if they are a winning combination. Keep your idea simple and provide evidence of your application design.
I'm very new to Java so any help would be appreciated.
https://linustechtips.com/topic/496091-java-help/
import randomwin = str(random.random())win = win[2:6]print(win)guess = input("Enter 4-digit number to guess: ")if guess == win:	print("You win!")else:	print("Wrong, you lose.")
Here's how you could do it python, hopefully it helps. The first 4 lines are generating a random 4-digit number. The print statement is so you can make sure it actually works, it tells you what the number is. Then you are prompted to guess a 4-digit number which is stored in a variable called guess. From there if guess is equal to win then you win.
You'll have to google how to do random numbers in java, but the rest is just printing, if statement, and input (Not sure I think you use scanners)
https://linustechtips.com/topic/496091-java-help/#findComment-6635735
Well before you get started coding, you'll have to decide on the project. What do you want to make?
https://linustechtips.com/topic/496091-java-help/#findComment-6636149
Yup, come up with an idea first and then we will be in a position to help you start thinking about architecture/design.
The single biggest problem in communication is the illusion that it has taken place.
https://linustechtips.com/topic/496091-java-help/#findComment-6637730
