NEX is a no go. Get an XFX or SeaSonic unit.
If you're an EVGA fanboy, get a G2.
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
EVGA B1, G1 and NEX are crappy. Get EVGA G2 or GS
that would make a good paper weight
no power?
edit: im an idiot
Ok, but how many Watts do you recommend?
Is this decent: http://pcpartpicker....supply-ssr650rm
You're good with that Seasonic. Your PC with overclocks will probably be under 350W.
It's way more than decent. Top quality.
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
A 650 watt PSU will do you fine here. If you want to expand your system like adding dual GPUs etc, without changing you PSU to a higher wattage one, a 750 watt PSU is good.
i5 4690k | MSI GTX 970 Gaming 4G | Swiftech H240-X | MSI Z97s SLI Krait Edition | Corsair Vengeance Pro 8gb ( 2x4gb ) | Corsair RM750 | Samsung 850EVO 250gb SSD & WD Caviar Blue 1tb HDD | Fractal Design Define R5
