This card omfg why did I buy it.
Ill start with my problem.
My gtx 970 gives a no signal constantly.
For example, I go to sleep, turn my computer off and go to bed. I wake up in the morning and turn my computer on and I recieve a no signal. This goes on for about 30 min. and I just keep restarting my computer for it to give signal.
Please help it is very fustrating and today it has been going on for about an hour. An hour of no signal.
https://linustechtips.com/topic/495353-gtx-970-help-please/
thats not normal for the card
something is faulty
don't blame the gpu specifically
first guess..is psu or ram...next would be the gpu
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
https://linustechtips.com/topic/495353-gtx-970-help-please/#findComment-6627801
Rest of system specs? Could be PSU not the card.
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
https://linustechtips.com/topic/495353-gtx-970-help-please/#findComment-6627808
Welcome to the forum.
What are your system specs outside of the card?
CPU, RAM, motherboard and PSU should be plenty.
DAYTONA
PROCESSOR - AMD RYZEN 7 3700X
MOTHERBOARD - ASUS PRIME X370-PRO
RAM - 32GB (4x8GB) CORSAIR VENGEANCE LPX DDR4-2400
CPU COOLING - NOCTUA NH-D14
GRAPHICS CARD - EVGA NVIDIA GEFORCE GTX 980Ti SC+ ACX 2.0 w/ BACKPLATE
BOOT and PROGRAMS - CORSAIR MP600 1TB
GAMES and FILES - TOSHIBA 2TB
INTERNAL BACKUP - WESTERN DIGITAL GREEN 4TB
POWER SUPPLY - CORSAIR RM850i
CASE - CORSAIR OBSIDIAN 750D
https://linustechtips.com/topic/495353-gtx-970-help-please/#findComment-6627852
Specs
AMD 9370
Corsair Vengence 2x4
Gigabyte 990 FXA
Psu- Corsair 750m
Im connecting via hdmi
Yea this has happened since I first build my computer
Hmmm......sounds like a defective card to me.
How long have you had the card? Could you RMA it?
DAYTONA
https://linustechtips.com/topic/495353-gtx-970-help-please/#findComment-6627906
