unstable OC - VRMs can take up to 120*C
https://linustechtips.com/topic/494147-vrm-temps-and-artifacts/#findComment-6615994
So 1175 is too much for my card?
you lost the silicon lottery - 1175 is average for a 390 - you just got a bad overclocker
https://linustechtips.com/topic/494147-vrm-temps-and-artifacts/#findComment-6616003
Well it was the "lite edition" that has a clock of 1005 mhz. Maybe thats why.
Those cards are lower-binned and usually get worse clocks and temps
https://linustechtips.com/topic/494147-vrm-temps-and-artifacts/#findComment-6616017
Oh, bummer.
you get what you pay for :/
https://linustechtips.com/topic/494147-vrm-temps-and-artifacts/#findComment-6616026
The performance difference is only small though, right? between this card and a more overclocking friendly one at max oc?
the normal one achieves around 1200 to 1250 usually. It's about 3-4% I'd imagine
https://linustechtips.com/topic/494147-vrm-temps-and-artifacts/#findComment-6616168
