First and foremost, my build is outdated and "just replace everything" is not the answer I'm currently looking for.  I use the computer mostly for work (email, web-based applications, minor photo editing) and from time to time I enjoy some casual gaming (HotS, SC2, Half-Life 2, Portal, and TF2 mostly).  I'm on a fairly limited budget, and I'm not opposed to purchasing pre-owned parts if it helps me to stretch that budget.  I'm also not opposed to using AMD cpu's but I am biased when it comes to gpu's and prefer nvidia based platforms.
My budget right now is $150-$200 and my choices are either to purchase a new GPU.. OR.. to upgrade my motherboard/cpu/ram.  The entire build will eventually be upgraded, I just can't decide where to start and can't do all of it at once.
Current build:
EVGA nForce 750i SLI motherboard (non-ftw edition - http://www.newegg.com/Product/Product.aspx?Item=N82E16813188033
Intel Core 2 Quad Q6600 (stock speeds - Zalman CNPS5X cooler)
8GB Corsair XMS2 DDR2-6400 (4x 2GB)
EVGA GeForce GTX 550 ti
ADATA SP600 128GB SSD boot drive
Seagate Barracuda 1 TB HDD mass storage
Corsair CX430 v2 PSU
NZXT H230 case
Thanks in advance for the guidance.
https://linustechtips.com/topic/493967-what-should-i-replace-first/
get a better cooler and then save for a new GPU
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
Has the Q6600 really survived that well even paired with DDR2? Im currently running it at stock speeds as I'm a novice over clocker at best (had it at 2.8Ghz with good temps but dealt with intermittent memory based BSoDs and gave up on it) and haven't really spent a lot of time trying.
As for GPU any suggestions in that price range? I've found a few pre owned GTX 650 TI boosts that are well below my budget but the 960 is sitting pretty at the top end of said budget.. Too many choices that are easily better than the 550 ti
