I am upgrading because my current laptop can't run games and keep the other prgrams (Chrome, word, etc) I use open in the background without getting really slow. So, I am on a tight budget (500CAD) and I would like upgradable features. I would like to play Skyrim with some mods (is that reasonable at lower settings?). All peripherals are bought already. Is this build okay/could I upgrade anything that would be significant and still stay within budget? I want to purchase my parts today. Thanks!
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor  ($89.98 @ DirectCanada)
Motherboard: ASRock Z97 Anniversary ATX LGA1150 Motherboard  ($82.49 @ Newegg Canada)
Memory: Team Vulcan 16GB (2 x 8GB) DDR3-1600 Memory  ($80.98 @ Newegg Canada)
Storage: Sandisk SSD PLUS 120GB 2.5" Solid State Drive  ($54.98 @ DirectCanada)
Case: Enermax ECA3280A-BR ATX Mid Tower Case  ($74.99 @ Amazon Canada)
Power Supply: EVGA 430W 80+ Certified ATX Power Supply  ($29.98 @ Newegg Canada)
Optical Drive: Lite-On iHAS124-14 DVD/CD Writer  ($17.00 @ DirectCanada)
Monitor: Acer V196HQLAb 60Hz 18.5" Monitor  (Purchased For $0.00)
Total: $430.40
Generated by PCPartPicker 2015-11-27 15:00 EST-0500
https://linustechtips.com/topic/493946-first-build-help/
If this is an entire build... Did you forget the GPU? Also, I don't think this build is gonna be one capable of high res 60FPS gaming xD
Yeah I know it won't be very good settings, I don't expect that. At this price range, is it worth it to get a GPU?
https://linustechtips.com/topic/493946-first-build-help/#findComment-6614317
I think it's impossible to be able to get a GPU. Also, that's impossible, your CPU won't be able to handle skyrim on low settings with good enough frame rate. The built-in GPU is only meant for loooking at a screen and webpages, word, powerpoint. Nothing near like gaming, so I'm telling you, it'll be impossible to play skyrim alone, never mind mods.
https://linustechtips.com/topic/493946-first-build-help/#findComment-6618595
