I've had this problem since I started using XTU benchmark, the same thing happens in both win7 and win10. I didn't botther to much, but it's frustrating that my overall score in a competition is dragged down by low XTU score. I can live with it as CPU performs like it should, any tips?
CPU-delided i5-4670k@4.6Ghz 1.42v R.I.P (2013-2015) MOBO-Asus Maximus VI Gene GPU-Gigabyte GTX 970 G1 Gaming@1582Mhz core/3744Mhz memory COOLING-Corsair H60 RAM-1x8Gb Crucial ballistix tactical tracer@2133Mhz 11-12-12-26  DRIVES-Kingston V300 60Gb, OCZ trion 100 120Gb, WD Red 1Tb
2nd  fastest i5 4670k in GPUPI for CPU - 100M
https://linustechtips.com/topic/492295-low-xtu-score/
Could you post a result for it, I do XTU and quite a few others on the forums do as well.
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
https://linustechtips.com/topic/492295-low-xtu-score/#findComment-6599276
https://linustechtips.com/topic/492295-low-xtu-score/#findComment-6599374
What score with what CPU?
~650-700 mark range. My CPU is in sig, but if you're on mobile 4670k.
https://linustechtips.com/topic/492295-low-xtu-score/#findComment-6599384
-snip-
dual channel memory will help the score and OC your Cache, it will help the scoring for XTU as well
|King Of The Lost|
https://linustechtips.com/topic/492295-low-xtu-score/#findComment-6599408
some are using stock clocks and still have higher score, I was using dual channel before, but this single channel memory is faster ( also in XTU ).
https://linustechtips.com/topic/492295-low-xtu-score/#findComment-6599469
CACHE
CACHE
CACHE
CACHE
Also what is labled as NB in CPU-Z in the memory tab
Overclock it
|King Of The Lost|
https://linustechtips.com/topic/492295-low-xtu-score/#findComment-6599548
CACHE
CACHE
CACHE
CACHE
Overclock it
But I shouldn't be having so low score even with cache at stock.
https://linustechtips.com/topic/492295-low-xtu-score/#findComment-6599666
Yeah you should be, cache plays a pretty significant role in XTU
|King Of The Lost|
https://linustechtips.com/topic/492295-low-xtu-score/#findComment-6599673
My best score with 700 marks has cache set to 4.5Ghz.
https://linustechtips.com/topic/492295-low-xtu-score/#findComment-6599704
-snip-
I'll be right back with doing a run at 4.5 Core and Cache with 2200 Cl9 Dual channel with tight secondaries see if something else is causing the issue or not.
|King Of The Lost|
https://linustechtips.com/topic/492295-low-xtu-score/#findComment-6599719
After that try single channel with the same settings as my memory.
https://linustechtips.com/topic/492295-low-xtu-score/#findComment-6599805
So here is 4.5 core 4.5 cache with 2200 CL9-12-12-19 1T with tight secondaries and hyper threading is disabled
give me a second to do with 1 stick at same primary timings as you
|King Of The Lost|
https://linustechtips.com/topic/492295-low-xtu-score/#findComment-6599833
@arniks8
Here is the Single channel same memory clock speeds and timings as you
|King Of The Lost|
https://linustechtips.com/topic/492295-low-xtu-score/#findComment-6599974
@arniks8
Your system is still getting ahead by a bit. I will give it a shot with my old memory.
https://linustechtips.com/topic/492295-low-xtu-score/#findComment-6599997
Not sure why since that was only at 4.5 core 4.5 cache with single channel on only 4 cores 4 threads
|King Of The Lost|
https://linustechtips.com/topic/492295-low-xtu-score/#findComment-6600218
am I seeing this right as the OP CPU as 4670k?
and your cpu as 4770k?
the difference, with HT disabled, is 2mb of cache.
Sim Rig:  Valve Index - Acer XV273KP - 5950x - GTX 2080ti - B550 Master - 32 GB ddr4 @ 3800c14 - DG-85 - HX1200 - 360mm AIO
Quote
Long Live VR. Pancake gaming is dead.
https://linustechtips.com/topic/492295-low-xtu-score/#findComment-6600813
Even still that shouldnt mean that I'm still scoring almost 100+ points ahead of him when doing single channel when doing 1:1 on core and uncore
|King Of The Lost|
https://linustechtips.com/topic/492295-low-xtu-score/#findComment-6600833
I won't be able to test with my old memory, my SSD died yesterday :angry: and I don't have any money for a new one.
https://linustechtips.com/topic/492295-low-xtu-score/#findComment-6607135
