internet connectivity issues and chassis intrude errors..
Solved by DevilishBooster,
Chassis Intrusion Error means that they motherboard has detected that the case has been opened and that someone might have tried to remove something. It's a feature on some motherboards. There should be a jumper that you need to reset. Consult your motherboard's manual on the proper procedure.
EDIT: If there isn't a jumper on the motherboard that you need to replace, then it's most likely a setting in the BIOS that you need to check. Again, consult your manual.
@mr_lactose Make sure you always follow your own threads.
