Thoughts on my build?
Go to solution Solved by DocSwag,
Thanks to all that comment last question is , is there a difference in having more ram slots being used
Let's say I want 16 gb ram and there's 4 slots is there a difference if I use more than 1/2/4
4x4gb =16
Or 2x8gb=16
Or just 16gb
Does it affect anything.
Yes it can make a difference. Nowadays most CPUs are either quad channel or dual channel. Most extreme editions are quad channel while mainstream ones (like what you have) are dual channel. Basically in quad channel the CPU treats the ram as four sticks, even if you have 8, while in dual channel the CPU treats it as you have 2 sticks, even if you have 4 sticks. Normally more ram sticks is better (if you have four sticks there are 4 whole buses you can access versus 2 with 2 sticks, meaning you could double your ram bandwidth) but because z97 only supports dual channel that means that even if you have 4 sticks it treats it as if you have 2 8gb sticks. Therefore there is no difference between 4x4gb and 2x8gb ram if they both have same clocks and latencies and all that. 2x8 is generally better because 1. It's generally cheaper 2. It gives you upgradibility. If you have 16 gb and need 32 all you have to do this pop in two more sticks. If all 4 slots are populated you need to buy a whole new ram set. Buying a new set is more expensive when compared to buying just 2 more sticks. 2x8gb is the better option unless you are going x99(which you aren't). Basically go 2x8 it's got benefits and no drawbacks.
http://pcpartpicker.com/p/GQLkpg My build, thoughts on it? Also what's the difference in MHz in ram ?
What is your budget? No skylake?
Windows 10?
The difference in MHz is the speed of the RAM. The higher the speed the faster they go!
Intel Core i7-6700k | 2 X Gigabyte 4GB GTX 970 Overclocked Edition | 16GB (4X4GB) DDR4 2133MHz Corsair Dominator Platinum | MasterCase Pro 5
ASUS Z170 Deluxe Motherboard | 256GB Samsung 840 Pro + Seagate 2TB Storage | Corsair Hydro H80i GT | Windows 10 Pro 64bit | Corsair HX850i
https://linustechtips.com/topic/492081-thoughts-on-my-build/#findComment-6596776
Looks pretty good. Not sure if that's one of the good power supplies, or the bad ones, though.
G3258 V 860k (Spoiler: G3258 wins)
i7-4790K | MSI R9 390x | Cryorig H5 | MSI Z97 Gaming 7 Motherboard | G.Skill Sniper 8gbx2 1600mhz DDR3 | Corsair 300R | WD Green 2TB 2.5" 5400RPM drive | <p>Corsair RM750 | Logitech G602 | Corsair K95 RGB | Logitech Z313
https://linustechtips.com/topic/492081-thoughts-on-my-build/#findComment-6596796
That RAM is a no go. Your board will just downclock it because it doesn't support its operating voltage.
Also, if this is a gaming PC, I would recommend getting a 4690K and a 390X instead.
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/492081-thoughts-on-my-build/#findComment-6596803
It's good.
https://linustechtips.com/topic/492081-thoughts-on-my-build/#findComment-6596807
What about this one?
CPU Cooler: NZXT Kraken X61 106.1 CFM Liquid CPU Cooler  ($108.99 @ SuperBiiz)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard  ($89.99 @ Newegg)
Video Card: MSI Radeon R9 390 8GB Video Card  ($294.98 @ SuperBiiz)
Case: NZXT S340 (White) ATX Mid Tower Case  ($54.40 @ SuperBiiz)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($96.99 @ SuperBiiz)
Operating System: Microsoft Windows 7 Home Premium SP1 OEM (64-bit)  ($119.98 @ OutletPC)
Total: $1280.92
Generated by PCPartPicker 2015-11-25 09:31 EST-0500
https://linustechtips.com/topic/492081-thoughts-on-my-build/#findComment-6596821
So what the difference if I buy a 2400mhz ram and 1600mhz ram ?
2400MHz RAM will run at a slower speed to match your motherboards maximum RAM voltage. In gaming, there is no difference. In rendering and editing, there is a marginal difference.
https://linustechtips.com/topic/492081-thoughts-on-my-build/#findComment-6596827
Looks like a great build, although there are cheaper R9 390's -but I see you're trying to stick with the MSI theme.
You're not going to notice a real world difference with the RAM, get whatever kit you like that is cheap. Personally, I'd go with the G.Skill Trident X's if you're sticking to 2400MHz.
LanSyndicate Build | i5-6600k | ASRock OC Formula | G.Skill 3600MHz | Samsung 850 Evo | MSI R9-290X 8GB Alphacool Block | Enthoo Pro M | XTR Pro 750w | Custom Loop |
Daily | 5960X | X99 Sabertooth | G.Skill 3000MHz | 750 NVMe | 850 Evo | x2 WD Se 2TB | x2 Seagate 3TB | Sapphire R9-290X 8GB | Enthoo Primo | EVGA 1000G2 | Custom Loop |
Game Box | 4690K | Z97i-Plus | G.Skill 2400MHz | x2 840 Evo | GTX 970 shorty | Corsair 250D modded with H105 | EVGA 650w B2 |
https://linustechtips.com/topic/492081-thoughts-on-my-build/#findComment-6596851
Because right now 16 go ram 1600mhz and 2400mhz are same price and the 18mhz is more for weird reason , they're both on deals I have 2x4 hyper x 1600mhz ram should I upgrade or keep the ram. (Like 50% sale off the corsair vengeance on Amazon)
Just go with 1600.
https://linustechtips.com/topic/492081-thoughts-on-my-build/#findComment-6596865
Higher speed is always better. The MHz on ram is the number of clocks per second the ram performs. Let's say your os needs to access the value of a variable "hi". On nearly all ram it will take about the same time. This is because of latency. Latency is basically the number of clocks between when you request for the info and when the ram retrieves it. Typically with higher ram clocks the latency becomes higher, so on nearly all sticks no matter ddr2 ddr3 or ddr4 it usually takes about the same time. The difference is memory bandwidth. Because the memory is clocked higher in one second you can "ask" for more information than if you have a lower clocked memory stick. For e most part memory bandwidth doesn't make a big difference in most games, but in some games(I believe battlefield 4 is one of them) the game is accessing the memory so many times a second that higher clock speeds can actually increase performance. Higher memory clocks is just a future proofing measure for the most part. However it does require a higher voltage, so either your 2400 MHz ram will run at a slightly reduced clock speed(though the latency will be less as well) in order to stay within the recommended voltage or you will have to run it higher than the recommended voltage. Keep in mind running at higher voltages than recommended can fry the cpu's memory controller over time. If they cost the same though always go with the higher clocked one. Hope this helps!
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/492081-thoughts-on-my-build/#findComment-6597097
If you are mostly gaming you could go with a 6600k instead and upgrade gpu to a 390x. Also what red will you be running at and what games will you be playing? Is this primarily a gaming machine?
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/492081-thoughts-on-my-build/#findComment-6597109
If you are into spending around 90 more bucks newegg has an amazing deal for a 960 gb ssd right now for only 200 bucks. You could just dump your hdd and ssd for this one. It's the same ultra 2 you're using for your ssd right now. If you want it though you should get it quick I think it's a Black Friday sale so it should be gone soon. If you don't want that much you can just spend 30 bucks more and get a 480 go ssd instead of 240 which is worth it too.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820173013&ignorebbr=1&nm_mc=KNC-GoogleAdwords&cm_mmc=KNC-GoogleAdwords-_-pla-_-Solid+State+Disk-_-N82E16820173013&gclid=Cj0KEQiA1dWyBRDqiJye6LjkhfIBEiQAw06IThkLL08TzcBwTBSDIswa6j5dsSLSO_12P1J8sxTDENQaAr2k8P8HAQ&gclsrc=aw.ds
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/492081-thoughts-on-my-build/#findComment-6597140
4x4gb =16
Or 2x8gb=16
Or just 16gb
https://linustechtips.com/topic/492081-thoughts-on-my-build/#findComment-6597271
4x4gb =16
Or 2x8gb=16
Or just 16gb
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/492081-thoughts-on-my-build/#findComment-6597492
Forgot to add... Just buying one 16 go stick is not where you should go as 2x8 is twice as fast.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/492081-thoughts-on-my-build/#findComment-6597497
Also ddr3 doesn't come in 16 go 8 is max so you can't do that anyways :) go 2 by 8. Best option.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/492081-thoughts-on-my-build/#findComment-6597505
