Hello, I just bought a Behringer Xenyx 802 Premium and 2 1/4in jack to 3.5mm converter and trying to figure out how to connect everything into which ports.
I would like to have a live audio feedback while I record (guitar/vocals).
Specs:
Mixer: Behringer Xenyx 802 Premium (non USB)
Microphone: Mxl V67gs condenser (48v phantom power)
No sound card basically unboard sound etc etc
https://linustechtips.com/topic/491864-need-help-with-ports/
In the top right corner of your board, you see two 1/4" jacks labeled 'main out' The two corresponding jacks on your cable should plug into your mixer there. The other end of the cable should plug into (i believe) the green 1/8" jack on the back of your motherboard.
This is the first time I have actually used my years of pro audio experience on this forum...
EDIT: I know it's stupid, but remember to enable the Phantom power on your board. You wouldn't believe how many times I have forgotten it and taken apart an entire setup just to realize I had to push a single fucking button.
My native language is C++
https://linustechtips.com/topic/491864-need-help-with-ports/#findComment-6594204
