So I am having problems with my CM Storm Trigger that I bought 2 years ago. Occasionally my keyboard will disconnect from the computer and give me a warning that there isn't enough power to operate the USB device. However, when I plug the keyboard into a USB 3.0 port it still had the same problem. My guess is that the USB port on my keyboard is worn out as I replace the USB cable and it still have the same problem. Anyone have any ideas on fixing this problem?
Thanks.
https://linustechtips.com/topic/491836-fixing-problems-with-the-cm-storm-trigger/
