SSD help
Go to solution Solved by WoodenMarker,
It's 250GB*
Go ahead and get it. You won't really notice the difference between it and other higher tiered ssds.
I wouldn't recommend getting an ssd just for games though.
Hey guys. Is the Samsung 840 240GB SSD good? Only reason am asking is because it's going very cheap for a 240GB SSD or am i better off getting a getting a more higher end SSD but in 128GB? Only reason i am asking is because i just bought a GTX 780 so i am on a bit of a budget.
Sponsored by Twitch and DxRacer.
https://linustechtips.com/topic/49160-ssd-help/
The 840 is great, and it would take a side-by-side comparison to really feel a difference. Go 240GB 840.
https://linustechtips.com/topic/49160-ssd-help/#findComment-654213
It's 250GB*
https://linustechtips.com/topic/49160-ssd-help/#findComment-657262
