I want to get a custom watercooling loop and was looking at jayztwosence video on this http://www.amazon.co.uk/gp/product/B008LZNXF0/ref=s9_dcbhz_bw_g147_i2_bs
would you recommend this or will i be worth the money to get something from someone like EK
its just to cool the cpu and i dont want to spend over 300 GPB/ 450 usd
My speakers dont even fit on or under my desk...PA's FTW
https://linustechtips.com/topic/491503-first-time-water-cooling-help/
what is "stupid amount"?
a custom watercooling loop will cost at least $400
I'd get an AiO if you're just going with a 240mm CPU loop. If you want expandability, get an EK Predator.
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
ive updated the first post with my budget on
is this just for the CPU? because adding a GPU will cost over $100 more
for first time watercooling you should do soft tubing, not hardline
there is a lot less risk of ruining your PC
i would recommend you buy a kit from EK or XSPC or alphacool
they will have everything you need and its about your budget
would you recommend this kit
 http://www.amazon.co.uk/XSPC-5060175584410-RayStorm-750-EX360-WaterCooling/dp/B00FVVEDWY/ref=sr_1_1?ie=UTF8&qid=1448388386&sr=8-1&keywords=xspc+kit
or
http://www.amazon.co.uk/NexXxoS-Cool-Answer-360-DDC/dp/B008LZOK66/ref=sr_1_3?ie=UTF8&qid=1448388483&sr=8-3&keywords=alphacool+kit
or
http://www.amazon.co.uk/EKWB-EK-KIT-L240-Water-Cooling/dp/B00XHVEWZ8/ref=sr_1_4?ie=UTF8&qid=1448388559&sr=8-4&keywords=ek+water+cooling+kit
