ok so what exactly do you mean by cleaner power to the cpu? and what do you mean by more power to it? ive currently got a mATX motherboard, if i upgrade to a ATX z77 motherboard then i will have better performance in gaming and windows? also im running a ivy bridge 2nd gen i5 3570k not OC'ed
https://linustechtips.com/topic/49137-mobo-power-delivery/#findComment-653838
Cleaner power to the CPU, meaning that at high voltages there will be less of a chance to damage your CPU.
https://linustechtips.com/topic/49137-mobo-power-delivery/#findComment-653839
Imagine clean power as a straight line, it would be better for the CPU as it is not constantly dealing with different voltage. "Dirty" power would be fluctuating and could damage your CPU at high voltages.
https://linustechtips.com/topic/49137-mobo-power-delivery/#findComment-653844
also i never overclock my parts..
If you're going will Intel, don't buy a "K" skew processor unless you think that overclocking may be an option in the future. If not, buy a non "K" skew processor and a H77/H87 motherboard, however if you want to overclock buy a Z77/Z87 motherboard.
Sam,
Intel Response Squad member
http://bit.ly/IntelRally
https://linustechtips.com/topic/49137-mobo-power-delivery/#findComment-653854
damage my cpu how? and how do i know if and or when it happened?
or do you mean it just wont last as long?
Unclean power can help degrade the silicone faster and thereby making the life span of the CPU shorter. High voltages will also do that.
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/49137-mobo-power-delivery/#findComment-653855
1.5V is the maximum voltage that a CPU can handle, if the voltage starts to go over this limit it will begin to damage your CPU due to degraded silicon.
Sam,
https://linustechtips.com/topic/49137-mobo-power-delivery/#findComment-653859
