Problems with CS:GO
My ping in game from when I do notice is around 55-65 ping. However, i do notice that sometimes "loss" and "choke" raise randomly from 0% to 6%ish. What does that mean?
Means that 6% of the packets sent were dumped into oblivion.
This is a form of unreliable network service, mostly apparent when you surf the web over long areas and the link between them being weak.
I play with a ping of 5-10 stable, 0% because the server is literally 50km away from me. (Fiber as well
The stuttering observed can be caused by the internet, the only way to clarify this is when you stutter in-game, look at the net graph and identify whether the loss goes up, or that your ping spikes up, both can be solved differently.
To solve packet loss, look for a better network connection such as maybe fiber optics, or perhaps a more expensive internet plan that focus on reliability.
OR
Look for servers within your region.
To solve random lag spikes, make sure that the spike is not caused by using a wireless network, if not then finding a better network supplier is in order.
