Stop auto starting a WU
Go to solution Solved by tobben,
Haven't tried this myself, but if you go into the advanced client, configure in top left corner
then the slot tab. Click on the slot in question, then click edit, go to the bottom and click add
on slot options. I assume the name will be pause-on-start and the value will be true/false.
Add that and it should automatically pause the slot whenever the client is launched, meaning
the slot will no longer automatically start whenever the client restarts.
Alternatively you can pause the slot after it has finished a wu with the "finish" option, or just
remove folding@home from the list of programs that are automatically launched whenever
the computer is booted.
https://folding.stanford.edu/home/guide/configuration-guide/#ntoc5
https://fah-web.stanford.edu/projects/FAHClient/wiki/ClientDifferencesV6ToV7
So I intentionally didn't start a new WU after my last one because it wasn't worth it tonight. But I had updates and rebooted, causing a new WU to auto start. Now it will stay there and lose points overnight since I always turn off my PC. (I'm one of those)
How do I prevent this from happening?
The Beast: CPU: i7 4790K GPU: EVGA 1080 SC Cooling: Dual NZXT Kraken x61 RAM: HyperX Fury 1866MHz Storage: SSD: 500GB Samsung EVO 840 + HDD: 1TB WD MOBO: Asus Z97 - a PSU: RM850x Case: H440 green-black Setup: Link PCPP: Link Evolution: Link
Gear: PS4 with custom skin // Astro A50 Xbox edition to fit colour scheme // Oppo PM-3 Planar Magnetic Closed Back Headphones // OnePlus One 64GB sandstone
Other stuffs: Acer aspire 128GB SSD 10GB RAM // MacBook Pro 13" 500GB SSD 16GB RAM // A 2009 iMac 21"
https://linustechtips.com/topic/490939-stop-auto-starting-a-wu/
https://linustechtips.com/topic/490939-stop-auto-starting-a-wu/#findComment-6583084
