This is the first time I'm posting here (sorry if I'm posting in the wrong thread),
I need to know if this build will work (as in everything is compatible with each other) for "1600x900" resolution gaming(Like getting constant 60 fps on witcher 3 with only high(not ultra) settings(hairworks off mind you),
specs are,
Asus H97-PRO Intel Motherboard
(http://www.amazon.co.uk/H97-PRO-Intel-Motherboard-Express-Socket/dp/B00K80N50E)
i5-4590 (http://www.newegg.com/Product/Product.aspx?Item=N82E16819116991)
Gigabyte gtx 960 g1 4gigs
(http://www.gigabyte.com/products/product-page.aspx?pid=5400#ov)
Corsair cx 500 watt psu
Gskill ram 8gigsx2 (Just found these cheap ones idk if they're ok)
(http://www.newegg.co...N82E16820231636)
Western Digital 1 TB SATA
(http://startechbd.com/Desktop-Components/Hard-Disk/Hard-Disk-WesternDigital/WESTERN-DIGITAL-Blue-1TB-SATA-HARD-DISK)
Some links are from my country(Bangladesh)
I'd like to know if these will work together(Not a tech savvy person here) and would really appreciate advice and suggestions...
https://linustechtips.com/topic/490668-need-advice-for-first-build/
I meant 380 and yes, but i would recommend getting a different power supply CX series are notorious for failing
damn I didn't know that! can you give me a psu suggestion for the r9 380(the one in the link says 750 watt reccommended)
(http://ucc-bd.com/sapphire-nitro-r9-380-4g-gddr5-pci-e-dl-dvi-i-dl-dvi-d-hdmi-dp-dual-x-oc-version.html)
You wont need a 750w for a 380... im running a 390 off of 650w... So i would try to get maybe a EVGA Gs or G2 if you want modular (Dont get Super Nova NEX)
also the Sapphire Nitro is a great card probably the best radeon coolers
thanks again man...I'll look into it
If you were wondering @CableMod doesnt have cables compatible with the Gs yet only the G2 sadly... so if you were worried about bad ass cables get the G2 :)
for the life of me I can't find a single evga psu in my country...found some coolermaster ones...are they good in making psu's?
