I'm going to build a pc with NZXT H440. I have a H100i which goes on top with two fans. The casing comes along with 4 fans, 3 up front and 1 in the back. The front fan mount has a dust filter.
With those in mind, what will be the best fan config for me to maintain a positive air pressure? As I live in a pretty dusty and hot place, bot dust control and cooling should be kept in mind with equal priorities.
Thanks In Advance!!  :)
https://linustechtips.com/topic/490657-air-flow-on-h440/
You need to have more intake fans than exhaust fans to maintain positive pressure. 2 front intakes and 1 rear exhaust should be enough.
60FPS Microwave
Intel Core i5-4670K | Galax GTX 970 EXOC | ASRock Z97E-ITX/ac | Team Elite 8GB 1600MHz | Gelid Black Edition | Samsung slowdown + WD Blue 1TB x2 | Cooler Master V550 | Corsair K65 + Logitech G100s | MasterCase Pro 3
https://linustechtips.com/topic/490657-air-flow-on-h440/#findComment-6579292
put the rad in the front as intake, thats what I made for my friend's PC works great, graphics card gets a bit hot
Early 2020 Build : Intel i7 8700k // MSI Krait Z370 // Corsair LPX 8x2 16GB // Aorus 5700 XT // NZXT H500
Early 2019 Build : Ryzen 2600X // Asus Tuff X470 // G.Skill Trident Z RGB 8x2 16GB // MSI RTX 2070 // NZXT H500
Late 2017 Build : Intel i7 8700k // Asus Prime Z370-A // G.Skill Trident Z 8x2 16GB // EVGA GTX 1080 Ti  // NZXT S320 Elite
Late 2015 Build : Intel i7 6700k // Asus Maximus VI Gene Z170 //  Corsair LPX 8x2 16GB // Gigabyte GTX 970 // Corsair Air 240
https://linustechtips.com/topic/490657-air-flow-on-h440/#findComment-6579294
but I have to consider the two fans also with the radiator. that leaves me with 3 intake and 3 exhaust (the rear one with rad fans)... also, gpu fans will work as exhaust fans.
https://linustechtips.com/topic/490657-air-flow-on-h440/#findComment-6579300
if I put the rad up front, my system might even burn! (just kidding)
I live in a pretty hot place... hot means REALLY HOT! At summer, it tops even at 40 degree Celsius!! 30-32 is an average!  :(
https://linustechtips.com/topic/490657-air-flow-on-h440/#findComment-6579313
The H440 comes with 4 fans by default, 3 front and 1 rear.
Intel 4690K 4.5 GTX 970 Strix ASRock Fatal1ty Z97 LGA 1150 Kingston HyperX Fury Black 16GB NZXT Black/Red Kingston 240GB SSD && Seagate Barracuda 7200RPM 3TB HDD Corsair H60 Corsair Builder 500W
PCPartPicker
https://linustechtips.com/topic/490657-air-flow-on-h440/#findComment-6579344
I live in the UAE, it can't be any hotter than that.
https://linustechtips.com/topic/490657-air-flow-on-h440/#findComment-6579678
60FPS Microwave
https://linustechtips.com/topic/490657-air-flow-on-h440/#findComment-6580035
I had that case with my nzxt x61 cooler and temps on my 4790k running at 4.5ghz @ 1.25 was around 85C under load.  That was after removing the hdd trays and adding a few more fans to the case.  It still fine as far as temps go because it won't get that hot while gaming.  However I didn't care too much for the temps and didn't wanna go under 4.5ghz so I switched to the enthoo pro and can't be happier.  However they did release an updated version of the case and now it's supposed to have better airflow but I haven't had a chance to try it out.
https://linustechtips.com/topic/490657-air-flow-on-h440/#findComment-6590612
I know it isn't airflow optimized but that hot? I live in a pretty hot place, will I cook up my system or something!?  :P  :(
https://linustechtips.com/topic/490657-air-flow-on-h440/#findComment-6591457
Yeah, it isn't good for airflow.  However if you aren't planning to overclock too high you'll be fine.  I'm debating whether or not to buy the new h440 since it's supposed to be better because I really like the look.
https://linustechtips.com/topic/490657-air-flow-on-h440/#findComment-6607465
