Hi, I am trying to upgrade my brother's computer for Christmas. He currently has a Amd 750k cpu, and a MSI 7770. Both parts were formerly mine, and he is in need of a performace boost. I am looking to get him a EVGA 970, because he wants to play Assassin's Creed Syndicate, and Rainbow Six : Siege. However, i am wondering if his CPU would be too slow for the 970. Thanks!
https://linustechtips.com/topic/490482-970-bottle-neck-help/
Yes. I would definitely upgrade his CPU.
https://linustechtips.com/topic/490482-970-bottle-neck-help/#findComment-6577539
Actually leave the system as it is and just add a r9 380 and a half decent power supply( if you don't already have one) and you'll be set
The 380 would perform well and most likely outperform and GTX 960. Just make sure you get him a good PSU. AMD loves power and heat.
i7-4790k @ 4.7GHz, 16GB DDR3 @1866MHz, MSI Gaming X 8G GTX 1080@2060MHz, 500GB SSD, 2TB Raid 0 HDD, 240GB Raid 0 SSD, EVGA SuperNOVA 850W PSU, Fractal Design Define R5 Windowed
https://linustechtips.com/topic/490482-970-bottle-neck-help/#findComment-6579421
