GTX 980ti Lightning modding
Metro
Hello
Has anyone put a different colour sticker on the yellow accents on the side of the GTX 980ti Lightning, like red, if so, what did you use for it.
Thanks
GPU[Two GTX 980ti Lightnings overclocked]-CPU[Core i7 5930K, 4.4Ghz]-Motherboard[MSI X99 Godlike]-Case[Corsair 780t Black]-RAM[32GB Corsair Dominator 3000Mhz Light bars]-Storage[samsung 950 Pro 512GB, Samsung 850 Pro 1TB and Samsung 850 Pro 512GB]-CPU Cooler[EK Predator 360mm]-PSU[EVGA 1600w T2 Individual cables Red]-Monitor[ASUS PG348Q]-Keyboard[Corsair K70 Red]-Mouse[Corsair M65 RGB]-Headset[sennheiser G4me one]-Case Fans[beQuiet Silent Wings 2]
Hello
Thanks
Getting some vinyl wrap for those would work very well if you don't want to paint it.
I will have a look, thanks, is that what is actually used or is it just a sticker
From what I can tell it's a plastic or metal decals that are painted yellow on the top. For vinyl wrap it basically works like a sticker over top of the yellow which you can always change out.
