CURRENT:
Motherboard: Asus H170-PRO ATX LGA1151 Motherboard  (€117.78)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR4-2133 Memory  (€59.39 @ Amazon Italia)
Video Card: Asus Radeon R9 390 8GB Video Card  (€342.00)
Case: NZXT Noctis 450 ATX Mid Tower Case  (€140.00)
Total: €1089.06
Generated by PCPartPicker 2015-11-22 21:17 CET+0100
CPU: I5 6400 (https://www.amazon.it/gp/product/B010T6CG7E/ref=ox_sc_act_title_4?ie=UTF8&psc=1&smid=A11IL2PNWYJU7H)
MOBO: B150M (https://www.amazon.it/gp/product/B014R8L0E0/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=A3KV3UONPZ16VH)
RAM: 16GB DDR4 (https://www.amazon.it/gp/product/B013J7P1YU/ref=ox_sc_act_title_5?ie=UTF8&psc=1&smid=A11IL2PNWYJU7H)
SSD: 120GB (https://www.amazon.it/gp/product/B00A1ZTZOG/ref=ox_sc_act_title_3?ie=UTF8&psc=1&smid=A2HNTIE6EB5Z5U)
GPU: GTX960 4GB (https://www.amazon.it/gp/product/B00UHHXXH8/ref=ox_sc_act_title_2?ie=UTF8&psc=1&smid=A11IL2PNWYJU7H)
PSU: 450W (https://www.amazon.it/gp/product/B00F4UYVZ6/ref=ox_sc_act_title_6?ie=UTF8&psc=1&smid=A11IL2PNWYJU7H)
CASE: NOCTIS450 (https://www.amazon.it/gp/product/B00WT0LDDC/ref=ox_sc_act_title_7?ie=UTF8&psc=1&smid=A11IL2PNWYJU7H)
SUGGEST? :)
https://linustechtips.com/topic/490146-help-is-good-or-not/
Get an AMD R9 380 instead of a 960 :)
The Beast: CPU: i7 4790K GPU: EVGA 1080 SC Cooling: Dual NZXT Kraken x61 RAM: HyperX Fury 1866MHz Storage: SSD: 500GB Samsung EVO 840 + HDD: 1TB WD MOBO: Asus Z97 - a PSU: RM850x Case: H440 green-black Setup: Link PCPP: Link Evolution: Link
Gear: PS4 with custom skin // Astro A50 Xbox edition to fit colour scheme // Oppo PM-3 Planar Magnetic Closed Back Headphones // OnePlus One 64GB sandstone
Other stuffs: Acer aspire 128GB SSD 10GB RAM // MacBook Pro 13" 500GB SSD 16GB RAM // A 2009 iMac 21"
https://linustechtips.com/topic/490146-help-is-good-or-not/#findComment-6573678
Why? :)
It's the same price but you'll get wayyyyy more performance out of it.
https://linustechtips.com/topic/490146-help-is-good-or-not/#findComment-6573699
r9 380  for 212,75€ (http://www.amazon.it/gp/product/B00ZPOC3UQ?keywords=r9%20380&qid=1448220715&ref_=sr_1_7&sr=8-7#productDetails)
What is it for?
If it's for gaming you could just get 8GBs of RAM and spend the rest of the money on a higher capacity SSD.
What about main storage? Do you already have a hard drive?
EDIT: as said above switch the 960 for a r9 380.
for 90€ 16GB for 60 8GB is for this
yes i have HDD already
https://linustechtips.com/topic/490146-help-is-good-or-not/#findComment-6573721
https://linustechtips.com/topic/490146-help-is-good-or-not/#findComment-6573736
i guess this card is a bullshit
the price is around 250 like gtx960 :)
Everyone here will recommend a 380 over a 960 though
https://linustechtips.com/topic/490146-help-is-good-or-not/#findComment-6573759
ahah grazie, italiani ovunque :) comunque intorno ai 1000€
ahah thanks, italian everywhere :) around 1000€
Give me a few minutes, I'll make you a "better" build. Are you planning on OCing?
Parla in Inglese il più possibile, i moderatori si possono irritare / Speak English as much as possible, mods could get irritated.
https://linustechtips.com/topic/490146-help-is-good-or-not/#findComment-6573760
thanks! i swhitch that :)
thanks patriot :) yes i don't speak in mother-lang  :D
https://linustechtips.com/topic/490146-help-is-good-or-not/#findComment-6573775
ok now the configuration is:
Total: €1040.00
Generated by PCPartPicker 2015-11-22 20:55 CET+0100
https://linustechtips.com/topic/490146-help-is-good-or-not/#findComment-6573900
NOT OC :)
Video Card: XFX Radeon R9 390 8GB Double Dissipation Video Card  (€358.87 @ Amazon Italia)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply  (€64.69 @ Amazon Italia)
Total: €1005.91
Generated by PCPartPicker 2015-11-22 20:57 CET+0100
Ho immesso alcuni prezzi manualmente, ma sono tutti venduti e spediti da Amazon, quindi fatti il carrello seguendo questa guida.
I manually put some prices and they are all sold by Amazon.
https://linustechtips.com/topic/490146-help-is-good-or-not/#findComment-6573931
Total: €1005.91
the problem is I WANT THE NOCTIS CASE xD
is not good a build like this? and why? thx m8! :)
Total: €1012.00
Generated by PCPartPicker 2015-11-22 21:02 CET+0100
https://linustechtips.com/topic/490146-help-is-good-or-not/#findComment-6573970
Total: €1012.00
There's no need in spending lots of money on a case. It's not worth it.
The one I made you is probably the best you could get out of that budget.
If you want to spend more on the case, then switch the one I chose for the one you want and spend more money. :)
https://linustechtips.com/topic/490146-help-is-good-or-not/#findComment-6573998
OK FINALLY on  €1077 for me is good can check again? :)
Total: €1077.06
Generated by PCPartPicker 2015-11-22 21:13 CET+0100
https://linustechtips.com/topic/490146-help-is-good-or-not/#findComment-6574066
switched now to 550w psu
Total: €1089.06
https://linustechtips.com/topic/490146-help-is-good-or-not/#findComment-6574088
Total: €1077.06
It's good, but get the Power Supply I chose, it's better and will give your system a little more head room.
If it's too expensive, then yours is still fine.
https://linustechtips.com/topic/490146-help-is-good-or-not/#findComment-6574101
Total: €1089.06
Perfect!
Now make a new post asking if that build is fine.
People will make it even better!
https://linustechtips.com/topic/490146-help-is-good-or-not/#findComment-6574111
