so after I finished the quest "freedom Trail" I got outside the church and boom fps went to 6 fps average pretty sure the gtx 970 should be more than enough for this game anyone have a similar problem ? I've restarted my pc installed the new drivers from nvidia and it's still sitting around 6 fps! I play at 1600x900 currently (1080p monitor got sold)
CPU: I5 7400 | Motherboard: MSI H110M  | RAM: 16GB G-Skill 2400mhz  | GPU:  NVIDIA  MSI Gaming 4G GTX 970 | Case: Tecware Quad | Cooling: Stock| Storage: Kingston 120gb SSD, 1TB Drive ,  | PSU: Seasonic 620 Watt 80+ Bronze Full Modular | Display: Devant 50 Inch Smart TV   |
https://linustechtips.com/topic/489757-fallout-4-low-fps/
Are you running borderless?
Case: NZXT Phantom PSU: EVGA G2 650w Motherboard: Asus Z97-Pro (Wifi-AC) CPU: 4690K @4.2ghz/1.2V Cooler: Noctua NH-D15 Ram: Kingston HyperX FURY 16GB 1866mhz GPU: Gigabyte G1 GTX970 Storage: (2x) WD Caviar Blue 1TB, Crucial MX100 256GB SSD, Samsung 840 SSD Wifi: TP Link WDN4800
Donkeys are love, Donkeys are life.                    "No answer means no problem!" - Luke 2015
https://linustechtips.com/topic/489757-fallout-4-low-fps/#findComment-6569893
I had a similar issue, The game was fully capable of running 60+ FPS but it refused to while presetinterval was on.
You can try turning Presetinterval off if it isn't already.  Its located in X:\Users\USERNAME\Documents\My Games\Fallout4\Fallout4Prefs.ini
Turn presetinterval from 1 to 0 and set the file to read only
https://linustechtips.com/topic/489757-fallout-4-low-fps/#findComment-6569919
6 fps? It seems like you run your game with integrated video card....Actually it's not, because I run it in ultra setting with HD4600 and I can get 10 fps...6 fps are not possible unless you plug the wrong cable...
CPU:Intel Core i7-5930K @4.5GGPU: 2 of MSI R9 390X GAMING 8G Graphics Card crossfire   Mobo:ASUS TUF SABERTOOTH X99    Ram:Corsair Vengeance LPX 32GB (4 x 8GB) DDR4 DRAM 2666MHz  SSD:2 of Samsung 850 Pro 512GB WatercoolerCorsair Hydro Series H100i GTX  CaseCorsair Graphite Series 780T   PSU: EVGA 1000 P2  80+platinum  Keyboard:Corsair Vengeance K70 RGB Mouse: Corsair M65 RGB black Monitor: LG277MU67 4K IPS FREESYNC
https://linustechtips.com/topic/489757-fallout-4-low-fps/#findComment-6573125
*FIXED* Needed to Delete "SpaceDesk" it was causing issues
https://linustechtips.com/topic/489757-fallout-4-low-fps/#findComment-6576570
