RGB Case lights
Go to solution Solved by Stardar1,
Yeah, imma go Hue+
Looking for RGB lights for case. Either LED or CCFL works.
Are there lights that receive power directly off of molex?
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
https://linustechtips.com/topic/489604-rgb-case-lights/
Most of them do, if you want an all in one solution look into the NZXT HUE or HUE+.
ok, thanks
Solitaire.
https://linustechtips.com/topic/489604-rgb-case-lights/#findComment-6568351
RGB lights are almost always LED I don't think I've ever seen an RGB CCFL light before that would be intereting.
In terms of RGB lights they all require a controller/remote to switch between different modes and colors, some good premade ones out there are by Modguru, or Icemodz.
https://linustechtips.com/topic/489604-rgb-case-lights/#findComment-6568355
Does the Hue come with LEDs? or do i need to buy separate strips?
Solitaire.
https://linustechtips.com/topic/489604-rgb-case-lights/#findComment-6568366
The HUE comes with LED's. I'm not sure about the original amount but the HUE+ comes with 4 strips and is expandable to 8.
does the Hue plus fit in the 5.25 inch? it looks like an external device
Solitaire.
https://linustechtips.com/topic/489604-rgb-case-lights/#findComment-6568401
i would get nzxt hue+ it can do alot more than just change color its pretty neat little system (basically everything you can do on rgb keyboard you can do on hue+)
also its about the size of an ssd
Project Iridium:   CPU: Intel 4820K   CPU Cooler: Custom Loop  Motherboard: Asus Rampage IV Black Edition   RAM: Avexir Blitz  Storage: Samsung 840 EVO 250GB SSD and Seagate Barracuda 3TB HDD   GPU: Asus 780 6GB Strix   Case: IN WIN 909   PSU: Corsair RM1000      Project Iridium build log http://linustechtips.com/main/topic/451088-project-iridium-build-log/
https://linustechtips.com/topic/489604-rgb-case-lights/#findComment-6568402
oh dang, thats tiny.
here's an oddity:
https://pcpartpicker.com/part/nzxt-case-accessory-8chue000000b
no category, and no hue+ as far as i can tell
Solitaire.
https://linustechtips.com/topic/489604-rgb-case-lights/#findComment-6568415
PCPartpicker have yet to update with the HUE+ most likely
ok.
the only way to find that part on PCPP is to do it through a google search. i have been unsuccessful at navigating the site to this page
Solitaire.
https://linustechtips.com/topic/489604-rgb-case-lights/#findComment-6568439
here's an oddity:
its pretty new so theirs not going to be any category for it yet on pcpartpicker they tend to take a while to add things like that but heres some info on it
https://www.nzxt.com/product/detail/163-hue-plus-case-accessory.html
https://linustechtips.com/topic/489604-rgb-case-lights/#findComment-6568444
Yeah, imma go Hue+
Solitaire.
https://linustechtips.com/topic/489604-rgb-case-lights/#findComment-6568453
