Need help!! I can't find this info anywhere and I'm kinda desperate. Will the MSI R9 380 fit in the corsair air 240?? I know length wise wont be a problem but I'm concerned about the width since corsair's spec sheet doesn't say anything about max GPU length??
The card is 268 x 138 x 40 and the max gpu length is 290mm, I'm not sure if it helps but the max CPU cooler height is 120mm. in which if that is also the max gpu cooler width then I'm kinda screwed
Urgent because i kinda want to get my PC built asap thankssss!!
CPU: Intel i5 6500 Motherboard: Asus H170M-E D3 Memory: Kingston HyperX Fury DDR3 2x8 GB GPU: -NIL- SSD: Samsung 850 Evo 250GB HDD: HGST Deststar NAS 3TB Case: Corsair 240 Air Power Supply: Seasonic M12II Evo 620W Display: Dell U2515H 25" 2560x1440 Keyboard: Corsair Strafe (Red LED + Cherry MX Brown) Mouse: Logitech Performance MX Speaker: Edifier M1360 2.1
https://linustechtips.com/topic/489079-help/
nvm
I3-4150 | Be Quiet! Dark Rock Pro 3 | 8GB KINGSTON FURY RAM | MSI Z97-G43 | HYPERX FURY 120GB SSD SAPPHIRE HD7950 VAPOR-X | Phanteks Enthoo Pro M | EVGA 500W | Corsair SP120's w/ NZXT Fan Hub
Plans: I5-4690K || EVGA GS 650W | KINGSTON FURY 8GB RAM  PCPARTPICKER: https://uk.pcpartpicker.com/
https://linustechtips.com/topic/489079-help/#findComment-6563220
Pcpartpicker says there is no issues, gotta remember that the gpu width includes the pci-e
hahaha but how reliable is Pcpartpicker? i mean does it check for width too? thts true i forgot abt pcie slot but i still want to be sure since that's like 200 bucks gone if it doesnt fit
https://linustechtips.com/topic/489079-help/#findComment-6563232
It's usually pretty reliable
hmm well then I guess i'll just have to try my luck then thanks!!
https://linustechtips.com/topic/489079-help/#findComment-6563249
This build here has your card in it i think and it fits fine.
https://uk.pcpartpicker.com/b/WLTH99
https://linustechtips.com/topic/489079-help/#findComment-6563251
