Hey guys, so I have actually really good internet right now where I'm at 70 down and 50 up. I wanted to do some streaming in my free time and decided to do CS:GO since that is a game I really enjoy playing. However when I start the stream and play my framerate drops from about 170+ fps down to 70-90 and is extremely choppy despite not dropping below 60 fps. In the game everything is set to low. I have a Lenovo y50 laptop that has relatively decent specs however I feel like it's something with the settings I have chosen. I'm trying to stream at 720p60, I have the x264 CPU preset set to medium currently.'
In case you don't feel like looking it up the laptops specs are:
CPU: intel i7 4700HQ @ 2.4Ghz
RAM: 8GB
GPU: Nvidia GTX 860M
OS: Windows 8.1 64 bit (haven't gotten around to getting Windows 10 I just got back from a month long training exercise.)
Any ideas?
https://linustechtips.com/topic/488939-streaming-causing-frame-drops/
What encoder are you using? Also, might want to check CPU usage. When you stream there will always be a bit of latency unless you are using a splitter to stream, just so you know.
x264, the CPU usage is looks to be about 50% when I stream
EDIT: My bad, it lowers really fast when I alt-tab out. It's in the 90's.
