So It's Christmas soon and I'm planning to get a new cpu, for now I'm thinking about an i5 4690K but I'm not sure if that would be the best deal for me, so I wanted to ask with a GTX 760 4GB GPU, what would the best cpu be ? Also, my socket is 1155.
Thanks very much, I really appreciate it :)
https://linustechtips.com/topic/488615-help-picking-a-cpu/
A i5-4690k does not fit into a 1155 socket. All 4th gen Intel Cores use socket 1150.
A good option for your socket would be the i5-3570k, which is one generation older, but still performs very well.
Make sure you have a Z77 chipset to make use of the unlocked CPU.
https://linustechtips.com/topic/488615-help-picking-a-cpu/#findComment-6557695
Thanks for the replies guys,
I have an i5 2310 right now, performs well but I'm looking to upgrade, would an i5 3770k perform over 60 fps on average in games like Battlefield 4 and GTA IV ?
Thanks again :).
Usually the GPU has the largest impact on framerate.
https://linustechtips.com/topic/488615-help-picking-a-cpu/#findComment-6557746
