Best positive air pressure fan setup
Im going to be building my first pc in a couple of months and I have a question about the air pressure.
I have decided to go with a positive air pressure setup and I need to recommendations for fan setups.
Here is my part list: http://pcpartpicker.com/p/bj9YsY
The case I will be using is a Cooler master Mater case 5 Pro which has space for either 2 or 3 140mm front fans, 2 140mm top fans and 1 140mm rear fan.
Since I will be using positive air pressure my question is, what is the best fan setup to get the best results.
I came up with this setup, 3 intake at the front and 1 exhaust in the rear causing the hot air to leave through the rear and empty top vents.
I am also taking suggestions for other setups and if you also use positive are pressure setup with the same fan setup please leave a comment below and tell me how affective it is.
Thanks
BTW I will also be using a Noctua NH-D15 CPU cooler which has 2 fans blowing towards the rear exhaust fan, will that some how alter the air pressure and/or disrupt the airflow?
First, for 2k, you could do better on the GPU, that setup looks overkill fot just gaming.
Second, the 3 intake and one exhaust would do good.
Third, the NH-D15 should be fine as it is not exhausting the air.
