Hello,
I have recently bought Star Wars Battlefront and have been having some issues
This is my most recent crash report:
Faulting application name: starwarsbattlefront.exe, version: 1.0.4.22789, time stamp: 0x5644b52d
Faulting module name: starwarsbattlefront.exe, version: 1.0.4.22789, time stamp: 0x5644b52d
Exception code: 0xc0000005
Fault offset: 0x0000000004f71cd4
Faulting process id: 0x165c
Faulting application start time: 0x01d1230da8c5c076
Faulting application path: C:\Program Files (x86)\Origin Games\STAR WARS Battlefront\starwarsbattlefront.exe
Faulting module path: C:\Program Files (x86)\Origin Games\STAR WARS Battlefront\starwarsbattlefront.exe
Report Id: d313eefd-8f04-11e5-901f-1c872c5f99f4
Can anyone please help me find and fix this problem because I really want to play this game
Thank you
https://linustechtips.com/topic/488106-what-is-the-problem/
this might be completely useless but try locating the .exe and start it from the core. Might be something wrong with origin
try starting it as a adminstrator
This could be the solution, however launching it via that method also launches the Origin launcher
https://linustechtips.com/topic/488106-what-is-the-problem/#findComment-6551070
I have tried launching it as administrator and it seems to work fine but I will say if anything bad happens, thank you so much
https://linustechtips.com/topic/488106-what-is-the-problem/#findComment-6551211
It's done it again even though I opened it as administrator, I am unsure on the problem
I would try it in another Windows admin user account. If it still quits, I'd reinstall Origin and the game.
I'd do the user account test first because of how large the game is and how long it takes to download/install. Origin will use the same files across multiple user accounts, so if it quits in more than one... it's something system-wide (such as the game or client, or maybe even Windows).
https://linustechtips.com/topic/488106-what-is-the-problem/#findComment-6552061
