Best CPU for a NAS?
wow that's a steal! Like the power draw it uses is negligible at best
. So you think its fast enough to run programs such as torrents? I was thinking of getting a small cheap ssd boot drive and using the 2 2tb as the storage for movies or files that i don't need all the time. Do you know any good tutorials about this? I think I might make the purchase now, I didn't think it would be this cheap
Yeah, I use transmission on it (a built in FreeNas plugin). There are plenty of tutorials out there on how to build it. You don't need an SSD with FreeNas because it will boot off a USB and that is how it is intended to be used. The power draw was one of the reasons that I got it as the system will be on 24/7. What is your knowledge level, FreeNas isn't super easy to use but with some learning it can be a very powerful software.
