My motherboard the Asus MAXIMUS VIII HERO ATX LGA1151 Motherboard has onboard ethernet at 1 x 10/100/1000 Mbps - what does that  mean?
Also I'm planning on running a cable from my router to the PC any tips or suggestions on what type of ethernet cable I should end up with?
thanks
https://linustechtips.com/topic/487582-ethernet-cable-help/
It means that the ethernet on the motherboard is capable of transferring data at a theoretical maximum rate of 1000Mb/s.
Go for Cat5e for your cable, unless your router is really far away from your computer (more than 100m I think is the limit for Cat5e's gigabit transfer speeds).
I actually couldn't underclock my 5 year old GPU to make it as slow as a next-gen console.
#pcmasterraceproblems
~Slick
https://linustechtips.com/topic/487582-ethernet-cable-help/#findComment-6544025
Its max speed is 1000mbps (1gbps)
If you were to plug in a cable that couldn't run at 1000mbps it would run at 100mbps, and so on for the 10mbps.
Same thing with 10gbps (10,000mbps) -> would run at 1000mbps
    CPU: 3930k  @ stock                                  RAM: 32GB RipjawsZ @ 2133Mhz       Cooling: Custom Loop
MOBO: AsRock x79 Extreme9                      SSD: 240GB Vertex 3 (OS)                     Case: HAF XB                     LG 34um95 + Ergotron MX Arm Mount - Dual Review
  GPUs: Gigabyte GTX 670 SLI                     HDD: 1TB WD Black                                PSU: Corsair AX 860                               Beyerdynamic - Custom One Pro Review
https://linustechtips.com/topic/487582-ethernet-cable-help/#findComment-6544042
