i5 4570 "overclock" Help needed!
Go to solution Solved by airdeano,
So even if I raise it to 140% it won't do any damage?
Means I can't really harm my CPU by chaning the BLCK or the Capability?
nope, but your RAM and PCIe won't be able to stand the overspeed of the
bus. only thing will happen is the machine will not boot or POST. stability of
the PCIe bus (GPU is usually part of this) will extremely overclock the GPU
(although you weren't trying to) to unachievable extremes. same for the
RAM, as you change the BLCK, the RAM speed also changes (not noted
now as it prolly is set on AUTO).
So I have been trying out some overclocking settings of my Asus Gryphon Z97M motherboard. Please keep in mind I have a non "k" series chip which is not overclockable!
I have never overclocked my CPU before but I read that one can push a non "k" series chip up to its advertised boost or beyond... So I have done the following:
Specs of my CPU:
i5-4570
clock: 3.2GHz
boost: 3.6 GHz
post-146320-0-26970500-1447876064_thumb.
You see the frequency is 3.7 GHz
post-146320-0-51588500-1447876119_thumb.
BCLK is at 103 which was done automatically by the motherboard
and finally what I am concerned about:
Does it actually make a difference if I choose a higher percentage?
I do not know much about overclocking, so I thought you might help me :D
Thanks in advance, and if instructions unclear, do not hesitate to ask :D
Firestrike Score: https://www.3dmark.com/fs/10388602
May the Force be with you all!
https://linustechtips.com/topic/487461-i5-4570-overclock-help-needed/
wait, 4570k? the 4570 cant OC
- im an idiot sorry -
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
Just know that even a few 100 Mhz on a non K chip could do some damage, they were not meant for OC past a few 100 mhz at that, just be careful :o
What exactly is the difference between a non-K chip and a K chip? They're the same die, they just have a locked multiplier.
No reason why you can't get a good BLCK OC, even a couple hundred MHz.
I know someone who overclocked her i3 to 4.0GHz stable.
remember, raising the BLCK speed also influences your PCIe bus speeds and
RAM speeds. only until the Z170 chipset, they allow independent strap tuning.
5-8% speed increase with BLCK tuning is not out of the norm.
Pretty much the locked multiplier is going to limit your abilites, and turbo boost sometimes just kicks it up to the limit by default. you can do a few 100 mhz but if your trying to do that it would have been a better idea to just buy a K chip and save for it if at the time you couldnt afford it.
Okay this sounds like good news, but what about the CPU cabaility? What does it change?
I never intended to overclock my CPU but i stumbled across this and thought, well why not try and squeeze out a little more performance for the money I spent :D
Complete BS, non k CPU`s just have locked multiplier.
CPU-delided i5-4670k@4.6Ghz 1.42v R.I.P (2013-2015) MOBO-Asus Maximus VI Gene GPU-Gigabyte GTX 970 G1 Gaming@1582Mhz core/3744Mhz memory COOLING-Corsair H60 RAM-1x8Gb Crucial ballistix tactical tracer@2133Mhz 11-12-12-26  DRIVES-Kingston V300 60Gb, OCZ trion 100 120Gb, WD Red 1Tb
2nd  fastest i5 4670k in GPUPI for CPU - 100M
It'll change a number of things on the CPU because you're raising the base clock. It's also called FSB overclocking. It affects RAM speed as well, if memory serves.
Someone correct me if I've screwed something up.
It`s about power derlivery, it shouldn`t make a difference at low clocks.
CPU cabaility is specifically for CPU, RAM and BLCK have other settings.
He meant that too much BLCK just won`t work.
No, CPU won`t even use that much. CPU cabaility would come in handy if were pushing high voltage on CPU.
I know on a z77 motherboard and an i5 2500, I can get 3.8ghz by setting the all core multiplier limit to 38. Runs fine with everything else left alone.
I see what you mean, I was playing a game (set the capability to 130%) and the GPU failed, meaning it just stopped working, so I will set it back to 110 or even 100% :)
But thanks for the advice!
