Hi all hopefully this is in the correct spot in the forums. My question is does a USB extension cable use power / computer resources when nothing is plugged into the other end of the cable on my computer, ive got the cable plugged into a USB slot in the motherboards IO shield and the other end of the cable is up next to my monitor to use for my USB devices. The image below shows a cable similar to myne, mynes just different brand and colour.
https://linustechtips.com/topic/48705-usb-power-resources/
No, there is no connection between any of the leads on the USB cable, so it is essentially just a USB port.
I do not feel obliged to believe that the same God who has endowed us with sense, reason and intellect has intended us to forgo their use, and by some other means to give us knowledge which we can attain by them. - Galileo Galilei
Build Logs: Tophat (in progress), DNAF | Useful Links: How To: Choosing Your Storage Devices and Configuration, Case Study: RAID Tolerance to Failure, Reducing Single Points of Failure in Redundant Storage , Why Choose an SSD?, ZFS From A to Z (Eric1024), Advanced RAID: Survival Rates, Flashing LSI RAID Cards (alpenwasser), SAN and Storage Networking
https://linustechtips.com/topic/48705-usb-power-resources/#findComment-649459
You could always find a way to measure the small power lost in extending the cables. There is always voltage drop based on distance and size of the wire. In short, no power is being draw just a VERY small amount being loss. Nothing you could ever notice! :)
https://linustechtips.com/topic/48705-usb-power-resources/#findComment-649468
