I'm struggling with what do with a question:
It's 2nd order differential equations.
basically it's the fact that:           y = e^(mx)
differentiate to get:                     y = m*e^(mx)
differentiate again and you get : y= m^2*e^(mx)
so here's the question:
Find the general solution to y'' + 4y' + 4y = 0
For the answer I got
e^(mx)(m^2 + 4m + 4) =0
so m = -2
so
y = Ae^(-2x)
However the answer says that there is a second term,
ANSWER:
(A + Bx)e^(-2X)
How does one get Bx ? I'm really not sure, I thought that I would require more initial condition to work out more terms...
https://linustechtips.com/topic/486957-math-help-please/
1) If you put in any values of A and B it works, so the general solution must contain the (A+Bx)e^.. as a specific solution.
2) The solution space has the correct dimension, so this is the correct answer.
3) The (A + Bx) came about because the solution to the quadratic was a repeated root, so you need a higher dimension term than just the A constant.
If you make a post contradicting mine that doesn't directly address my claims, or cites 'facts' without evidence, I'm probably not going to bother responding to it, because you probably didn't bother reading my post properly, and because life is too short. It doesn't mean I don't have an answer for you. It means I'm not dignifying you with a response.
https://linustechtips.com/topic/486957-math-help-please/#findComment-6535550
