I have been thinking about building my own pc for awhile and have made many changes to my build. Keep in mind this is for gaming but do not plan on overclocking and also do not mind playing on medium settings
http://pcpartpicker.com/p/xLCMsY
Does this one work? Sorry this is my first time on here
https://linustechtips.com/topic/485673-idea-for-my-first-pc/
You can't just use the URL of the page, you have to get the specific URL that is in a box towards the top of page.
EDIT: It's called PERMALINK
[Out-of-date] Want to learn how to make your own custom Windows 10 image?
Desktop: AMD R9 3900X | ASUS ROG Strix X570-F | Radeon RX 5700 XT | EVGA GTX 1080 SC | 32GB Trident Z Neo 3600MHz | 1TB 970 EVO | 256GB 840 EVO | 960GB Corsair Force LE | EVGA G2 850W | Phanteks P400S
Laptop: Intel M-5Y10c | Intel HD Graphics | 8GB RAM | 250GB Micron SSD | Asus UX305FA
Server 01: Intel Xeon D 1541 | ASRock Rack D1541D4I-2L2T | 32GB Hynix ECC DDR4 | 4x8TB Western Digital HDDs | 32TB Raw 16TB Usable
Server 02: Intel i7 7700K | Gigabye Z170N Gaming5 | 16GB Trident Z 3200MHz
https://linustechtips.com/topic/485673-idea-for-my-first-pc/#findComment-6511580
https://pcpartpicker.com/parts/partlist/
I was wondering why that looked so familiar, then I realized I was looking at my own build.  You gotta use a link that looks like ths:  http://pcpartpicker.com/p/YThYsY
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/485673-idea-for-my-first-pc/#findComment-6511602
Personally I'd recommend not getting the two corsair case fans even if you have a promo; you'd be better off spending the $30 from them on a better graphics card.
How about something like this:
http://pcpartpicker.com/part/gigabyte-video-card-gvn950wf2oc2gd
or
http://pcpartpicker.com/part/evga-video-card-02gp42957kr
The newer 950 will offer better performance than a 750 Ti and are more power and energy efficient, therefore producing less heat for improved performance reducing the need for the extra fans.
According to the case website it includes two fans, which should be sufficient in a first build. You can always buy an extra fan down the road if needed but once you lock in your graphics card you're going to be spending a lot more to upgrade it in the near future so it's best to get the best card within your budget at the time (except for when you're looking at top tier cards).
https://linustechtips.com/topic/485673-idea-for-my-first-pc/#findComment-6517294
