CPU: i7-4790k @ 4.4GHz | GPU: Gigabyte GTX 970 Gaming | PSU: Corsair CX600M | Cooler: NZXT Kraken x41 | Motherboard: Asus z97-E | Case: Zalman Z11 Neo | RAM: 16GB G.Skill Ripjaws X @ 2400MHz | Storage: 3TB Seagate HDD, 120GB Team Dark SSD |  OS: Windows 10 Pro
https://linustechtips.com/topic/485592-goodcheap-fan-case/#findComment-6510513
I bought an Enermax silent wings fan about 3 years ago, it's still running up to now and I don't even have to clean it that often (no dust filter in the chassis)
The same time I bought a Cooler Master fan and it died this year :(
Note that I usually leave my computer on and turn it off during weekends.
On a side note, I have a ThermalTake fan that's about 5 years old already. I had to clean it though as at some point it stopped because of dust build up near the motor,
You can bark like a dog, but that won't make you a dog.
You can act like someone you're not, but that won't change who you are.
Finished Crysis without a discrete GPU,15 FPS average, and a lot of heart
How I plan my builds -
For me I start with the "There's no way I'm not gonna spend $1,000 on a system."
Followed by the "Wow I need to buy the OS for a $100!?"
Then "Let's start with the 'best budget GPU' and 'best budget CPU' that actually fits what I think is my budget."
Realizing my budget is a lot less, I work my way to "I think these new games will run on a cheap ass CPU."
Then end with "The new parts launching next year is probably gonna be better and faster for the same price so I'll just buy next year."
https://linustechtips.com/topic/485592-goodcheap-fan-case/#findComment-6511491
Can you link us to where you're shopping?
https://linustechtips.com/topic/485592-goodcheap-fan-case/#findComment-6512678
