looking to spend no more than 100 pound (preferably lower) and get a reliable, decent liquid cooler for a i7 4790k
The Kraken x61 is probably the best.
Did my post help you? Then make sure to rate it!
Check out my post on symbolic links! || PSU ranking and tiers || Pokemon Thread
https://linustechtips.com/topic/485183-best-cpu-water-cooler/#findComment-6505984
Get the max that your case can support that is expandable. You never know, maybe you would want to include your GPU in the loop.
Like the EK predator, Fractal Design Kelvin, Swiftech H2, etc.
Echelon Mk 2.11
  • Processor: Intel Core i5-6500
  • Cooler: Cryorig H7 (With a 120 mm Thermaltake Riing RGB)
  • Motherboard: MSI B150M Bazooka Plus
  • Memory: 16 (2x8) GB DDR4 Kingston HyperX Fury (Black)
  • Video Card: Sapphire NITRO R9 390 (Stock)
  • Storage:  1 TB Western Digital Blue
  • Power Supply: 520 W Seasonic M12II Evo (with custom extensions and cable combs)
  • Casing: NZXT S340 Elite (Matte Black)
  • Fans: 2x 120 mm & 3x 140 mm Thermaltake Riing RGB
  • Display: 22 " LG Flatron L227WTG-PF LCD (OCed to 76 Hz)
  • Keyboard: Logitech K120
  • Mouse: Logitech G402 Hyperion Fury
  • Mousepad: SteelSeries QcK
  • Operating System: Windows 10 Pro (64-bit)
https://linustechtips.com/topic/485183-best-cpu-water-cooler/#findComment-6506070
save a little longer and get the new Ek all in one it's a lot cooler at lower/quieter fan speeds
http://www.scan.co.uk/products/ekwb-ek-predator-240-hydro-cooler-2x-vardar-pwm-fans-for-intel-cpus
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/485183-best-cpu-water-cooler/#findComment-6506086
