 Hello,
So today I decided to clean/upgrade my PC, I applied some new thermal paste,dusted it out and even installed 16gb more ram. But then I realized there was a small amount of water on the water cooling fans under the radiator. It wasn't much, but I could tell water had been there. So I was wondering is this normal and if not should I just wait a while to see if this is reoccurring before sending it back?
My first thoughts was it was from the aircan as it started to get really cold at times and left some residue, before I took a break.
CPU COOLER: Corsair H105
Thanks for the help again everyone!
Might add this later...
https://linustechtips.com/topic/484718-water-cooler-leak-help/
And how would I test it with the PC?
Remove it, plug in a connector from your PSU, use a fan header on the board if it needs one.
Wires are magical in that you can connect to them even outside of the case.  ;)
Chernobyl
AMD FX8350 @ 5GHz | Asus Sabretooth 990FX R2 | 16GB HyperX Savage @1950mhz CL9 | 120GB Kingston SSDNow
EK AMD LTX CSQ | XSPC D5 Dual Bay | Alphacool NexXxoS XT45 240mm & Coolgate Triple HD360
Kraken
Intel i5 4670K Bare Die 4.9GHz | ASUS Maximus VII Ranger Z97 | 16GB HyperX Savage 2400MHz | Samsung EVO 250GB
EK Supremecy EVO & EK-MOSFET M7G  | Dual 360mm Rads | Primochill CTR Phase II w/D5 | MSI GTX970 1670MHz/8000MHz
Graphic Design Student & Overall Nerd
https://linustechtips.com/topic/484718-water-cooler-leak-help/#findComment-6501417
Thats why I'm not 100% sure + the fact I was using an aircan what was blowing air at around 7 degrees at some points (estimate).
I saw a little fan oil on some of my generic fans in the front of my case and shit a little bit.  After a little searching, I realized that's all it is.
A decent idea is to use a paper towel or toilet paper to dab it up.  Corsair uses a green like coolant.  If whatevers on your fans is green.. you've got a problem
i7 6700k // H110i GTX, 4xNoctua 140mm Industrial 3k // Asus Z170 Pro Gaming // 8GB 2400mhz // MSI GTX 970 // Enthoo Pro M
https://linustechtips.com/topic/484718-water-cooler-leak-help/#findComment-6506195
Take it off the PC is your first step.
Put it by the side of your pc on top of towels (without your pc running ofc) and plug in onto the powersupply and a fan header if it needs it, (make sure to put the stock cooler onto your PC and remove the overclock before booting into widnows). If it leaks then you should know what it is
My PC:
MOBO: MSI B450 Tomahawk Max, CPU: AMD Ryzen 5 3600, Cooler: BeQuiet! Dark Rock 3, GPU: Gigabyte GTX 1050ti D5 4G, Ram: 16GB (2x8) HyperX Fury DDR4, Case: NZXT S340, Psu: Be Quiet! Pure Power 11 600W , HDD's: WD 1TB Caviar Blue, WD 256GB Scorpio Blue, WD 2TB Caviar Blue  SSD: Sandisk SSD PLUS 240Gb
https://linustechtips.com/topic/484718-water-cooler-leak-help/#findComment-6506274
