Component help
Go to solution Solved by Guest,
Will an i7 4790k bottleneck a 980ti? Also, does the Msi Z97 Gaming 5 mobo support overclocking?
No and yes
The i7 will defiantly not bottleneck the 980ti.
All Z series motherboards support overclocking but you can overclock on basically any motherboard z series or not.
Btw have you considered skylake?
No and yes
https://linustechtips.com/topic/484503-component-help/#findComment-6498802
No, and all Z motherboards support overclocking.
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
https://linustechtips.com/topic/484503-component-help/#findComment-6498806
The i7 4790K will not bottleneck the 980 Ti.
Also, all boards running the Z97 chipset are capable of overclocking...at least, to my knowledge.
DAYTONA
PROCESSOR - AMD RYZEN 7 3700X
MOTHERBOARD - ASUS PRIME X370-PRO
RAM - 32GB (4x8GB) CORSAIR VENGEANCE LPX DDR4-2400
CPU COOLING - NOCTUA NH-D14
GRAPHICS CARD - EVGA NVIDIA GEFORCE GTX 980Ti SC+ ACX 2.0 w/ BACKPLATE
BOOT and PROGRAMS - CORSAIR MP600 1TB
GAMES and FILES - TOSHIBA 2TB
INTERNAL BACKUP - WESTERN DIGITAL GREEN 4TB
POWER SUPPLY - CORSAIR RM850i
CASE - CORSAIR OBSIDIAN 750D
https://linustechtips.com/topic/484503-component-help/#findComment-6498810
