Hello everyone again,
So basically this christmas I'm finishing of my PC build finally with a new desk. So basically I'm wanting to get rid of my (BenQ XL2411Z) and get something very similar but with a DISPLAY PORT + HDMI, as thats the only problem with the XL2411Z. So something 1920x1080 16:9 widescreen ,144hz and 1ms? And on top of that I'm also looking for a 4k monitor (4k,ips,24"). If anyone could suggest two monitors for me what fit the description that would be awesome!
Thanks for the troubles!
Might add this later...
https://linustechtips.com/topic/483309-pc-upgrading-help/
Question 1, what is your budget? Question 2, can I have your BenQ?
IT Manager working in the Education sector.
https://linustechtips.com/topic/483309-pc-upgrading-help/#findComment-6483605
Well you can get a really good 1080p with $700!!! You could probably get a 1440p 144hz 1ms monitor like the rog swift (or something newer). I am assuming you can handle 1440p gaming since you are also getting a 4k monitor right?
Yes, But I'd rather game on 1080p as it's more future proof and better for competitive gaming. The 4k Is more of a viewing/editing monitor.
https://linustechtips.com/topic/483309-pc-upgrading-help/#findComment-6484402
$800 for 4k & $700 for the 1080p... And as in buy it? aha I'm going to sell it locally :D
Anyway I was thinking about the benq xl2430t for the 1080p?
Ok, well if it is 1080p your looking for, for only gaming I would recommend wide screen like the LG Ultrawide 34UM95-P 34" LED Monitor with IPS Panel. http://www.scan.co.uk/products/34-lg-ultrawide-34um95-p-monitor-ips-panel-320cd-m-dp-hdmi-thunderbolt-silver  It is also below your budget.
https://linustechtips.com/topic/483309-pc-upgrading-help/#findComment-6487923
