Hyper 212 evo, cheap and good.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/483132-cpu-cooler/#findComment-6481063
i have a intel i7 920 cpu and its making quite a lot of temparature i don't want to change it out i think its fine, i am just looking for a new cooler any1 has any ideas?
Where are you from, there might be cheaper or better options than a 212 evo.
What is your region or for example the price for a CoolerMaster Hyper 212 EVO VS BeQuiet! Pure Rock?
http://linustechtips.com/main/topic/334934-unofficial-ltt-beginners-guide/ (by Minibois) and a few things that will make our community interaction more pleasent:
1. FOLLOW your own topics        2.Try to QUOTE people so we can read through things easier
3.Use
PCPARTPICKER.COM - easy and most importantly approved here        4.Mark your topics SOLVED if they are
Don't change a running system
https://linustechtips.com/topic/483132-cpu-cooler/#findComment-6481084
