Quick Question - Connection Chain/Link
Hi, I was just wondering and I'm planning out a network map, just a small starter one. If a PC connects to a server and that server is connected to a modem that has an internet connection, they should all be able to have an internet connection right? Obviously all open settings, nothing strict and tight.
https://linustechtips.com/topic/482833-quick-question-connection-chainlink/
If you bridge the network adapters then it should work, but I would suggest against it if possible.
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
