help ME CHOOSE! PLs :))
Sup! I have a problem cuz i have to buy a new monitor which is 144 hz and i have 2 monitors to choose so its: Benq XL2411Z or Acer XB240H
I usually play ONLY counter strike Global offensive and atm i have an 60hz monitor and i need one with 144hz so guys plss help me choose one out of the 2 that i named thx :)
https://linustechtips.com/topic/482566-help-me-choose-pls/
Honestly, I would probably just stick with the 60Hz monitor.
The Chocolate Covered Computer
CPU: Intel Core i7 5820k @ 4.0GHz l GPU: EVGA GTX 980 TI FTW MOBO: ASUS x99 Deluxe LGA 2011-v3 l RAM: 16GB RipJaws 4 DDR4 @ 2400MHz l SSD: Intel 730 Series 240GB l HDD: Seagate 2TB SSHD, 2TB HDD 1TB HDD, 3TB HDD l PSU: EVGA Supernova 1200P2 l Cooler: Corsair H60 Liquid Cooler l Case: Corsair Carbide Series 540 Air ATX Cube Case l Monitor: LG Flatron E2711
l Keyboard: Razer Blackwidow Tournament Edition l Mouse: Razer Deathadder 2013 Edition l Headset: Razer Kraken Pro 7.1 Chroma Gaming Headset
https://linustechtips.com/topic/482566-help-me-choose-pls/#findComment-6473722
It isnt worth buying a new monitor just for refresh speed at the same resolution (which i assume is what you are doing).
I would probably go Acer though
I3-4150 | Be Quiet! Dark Rock Pro 3 | 8GB KINGSTON FURY RAM | MSI Z97-G43 | HYPERX FURY 120GB SSD SAPPHIRE HD7950 VAPOR-X | Phanteks Enthoo Pro M | EVGA 500W | Corsair SP120's w/ NZXT Fan Hub
Plans: I5-4690K || EVGA GS 650W | KINGSTON FURY 8GB RAM  PCPARTPICKER: https://uk.pcpartpicker.com/
https://linustechtips.com/topic/482566-help-me-choose-pls/#findComment-6473782
Well I would choose the Acer if you have an Nvidia GPU and you want gsync, otherwise the Benq!
But I personally would just get a 1440p panel :)
I understand your want for 144hz though! If its worth it to you then do it :P
https://linustechtips.com/topic/482566-help-me-choose-pls/#findComment-6473789
lol why so u could choose between 144 hz monitor and 60 hz monitor and u choose the 60 hz one ????
What I mean is, stick with that you have.
https://linustechtips.com/topic/482566-help-me-choose-pls/#findComment-6484400
If you feel the need to buy a new monitor just for CSGO, then by all means. I'd go with the the Acer.
https://linustechtips.com/topic/482566-help-me-choose-pls/#findComment-6484414
